Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have a Whirlpool Ultimate Care II washer and I took the three bolts out to drop the gearbox and motor assembly. It only dropped about 3/4" and got hung up and not won't go back to the original position. how do i get it back to the original assembled position?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Whirlpool Expert
  • 154 Answers
MAN, YOU MAY BE IN TROUBLE, YOU FORGOT TO UNBOLT AGITATOR, TAKE BOLT OUT OF AGITATOR AND TRY AGAIN
Posted on Feb 07, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    How do you remove the agitator from the Maytag Ultimate Care II washing machine?
    Pull out the softener cup. Remove the water seal by pulling on the two wings. Remove the retaining bolt with an 11mm socket and a couple extentions. Pull the entire agitator out of the machine. With a sharp pointed tool cut the four melted portions of the white plastic **** even with the top of the clear plastic ratchet assembly by inserting your tool thru one of the three holes in the side of the top agitator. Pull the top agitator from the bottom agitator.
    Sep 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    How do I change the clutch assembly
    take the agitator off ...turn machine on back...take three bolt out of transmission and remove transmission.you will see clutch remove clip.
    Aug 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    How do I take off Whirlpool Washer cabinet to get to the pump
    Go to;
    http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
    click on your model number. The new window will give diagrams in the left-hand side.
    Click on the diagrams. This will show the assembly of the unit. Use this as a guide for dis-assembly and re-assembly and do not mix-up parts as they are removed.
    Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II drum does not spin.
    Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
    Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool washer LSQ9549LW1- loud thunks at end of spin cycle
    you can goto sears.com and goto parts, put in your model # and they have a parts and diagram that you can look at.. sound like your basket block (which holds your basket on the gear shaft) is loose.. or 3 bolts on bottom of washer the holds gearbox to frame is loose.. good luck
    Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer basket has dropped 1.5"
    Different models use different devices to "suspend" the tub. Please verify the exact make / model.
    Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ8220HQ0
    You have to start eliminating them one by one a common reason is the spin tub mounting block if the motor comes on and clutch is driving basket drive and brake assembly than this is the problem.
    Oct 04, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
    It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
    Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    105 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
