Right half of my speaker inputs on the sub do not send signal
I heard putting both speakers on one side would remedy the lack of sound, but then I don't get the stereo sound, and this is a great speaker set.
    Genius:
  • Audio Player... Master
  • 1,667 Answers
If both speakers work on one side and do not work when put on their respective sides, this indicates that the amplifier needs to be serviced.
You will have to give the amplifier/receiver to a service center to have it repaired. Ask for an estimate. These repairs may not be low in cost.
Jerry G.
Posted on Jul 20, 2009
Hello I have another question but this is containing my back up surround sound receiver til I can find a Sony receiver that I like. Ok this receiver is a AV receiver model ht-r420 onkyo surround sound...
Subwoofer sockets
The HTR-420 has only a single subwoofer output. It is the socket on the lower left corner. The other subwoofer socket is part of the multi-channel input.
Because of the age of the 420, it comes from a time when optical and coax connections were not so common and DVD players had 6x phono/RCA sockets to send out the surround signal in analogue format. The multichannel input is for sending a signal in to the amp, and not for getting a signal out. That's why the sub doesn't get a signal from that socket. Use the proper subwoofer out. That's what it is there for.
Speakers A+B
The 420 was designed to run Speakers A+B together if required. However, you must observe the minimum impedance loading if you connect up two sets of front speakers and run them simultaneously.
The minimum Impedance for each set of front speakers is 8 Ohms. If you're recycling old surround speakers from a Home-Theater-in-a-Box system, or the speakers have no labels for impedance on the backs then you can be fairly sure they are not 8 Ohm. That could be the problem.
Sep 09, 2014 | Audio Players & Recorders
I have a s108sp subwoofer with a right and left input assuming this is for a cable going to one input on my Sony reciever. The subwoofer also has inputs for speakers. Do I plug the speaker wires into...
Hey there houleo!
If your subwoofer has a stereo input and stereo outputs, then it's a good idea to send the signal from your receiver to the sub, then out to the other speakers you have hooked up. Some subwoofers will take the low frequencies out of the signal to the left and right speakers, so that the sub handles it alone. This often gives a nice crisp sound.
Reciever/amplifier
l l l l V V Subwoofer l l l L------> Right speaker
V Left speaker
If this helps you out, I'd appreciate if you rated me well :) If you've got any more questions, feel free to ask! Cheers! -The Chicken
May 26, 2011 | Acoustic Research S108PS Subwoofer
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Hi, I have the Kenwood Subwoofer KS-201-HT, my question is how do I connect it to my receiver?
usually subs have outputs 4 ur monitors however if ur sub is active @ ur monitors are passive then you need 2 connect sub 2 ur tape loop with rca connections,usually you use the send signal from ur reciever which would norm connect to ur tape input , if the sub is passive then u connect direct to speaker output on amp then monitors to the sat connections on sub
Oct 12, 2010 | Kenwood SW36HT Subwoofer
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
Wen radio is turned up ampp goes into protection
No diagram but you can printthis out. Choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) You need to put the settings to low hertz and no high settings. Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides!). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps
Oct 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need a diagram of hw to hook 2 subs to 4 channel amp
Oct 08, 2009 | Kenwood Car Audio & Video
Gotta 07 Denali and in the past when I put my system in any of my vehicles, I just throw my line converter on the rear speakers and all is good. My question is can you still do that with the factory Bose...
Hello russet327,
There should be no difference in the signal on the speakers themselves. It's simply an AC sine wave, varying in amplitude and frequency.
There might be a phase difference that could affect the sound of your subs, but most amps will allow you to adjust or at least select the proper phase. I'd recommend wiring the LOC the same as you have always done it. "Grabbing" a signal before it gets to the factory amp could be even more problematic because the signal will most likely be at too low of a level for your LOC, the wiring may be shielded, and the impedance will be an input impedance in the range of 20-25K ohms instead of the 4 ohms that the LOC is expecting.
Hope this helps.
Sep 19, 2009 | Car Audio & Video
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
26 people viewed this question
 Grubhead
Grubhead
