Question about Electrical Supplies
Genarator runs short period of time & shut down
Genarator runs off of motor home fuel t
  • 6,674 Answers
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Posted on Aug 05, 2009
No ac output on a winco 9000 multi fuel home power genarator
How long has the unit sat?
After long periods the rotor loses it's residual magnetism and may have to be field flashed for a few seconds. Also check that the rotor slip rings are clean and shiney
Nov 01, 2013 | Winco Electrical Supplies
Pressure washer runs for short period of time then shuts down
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, ~~
Feb 18, 2012 | Garden
Dryer runs for a short period of time and then shuts down without any error code but with a "clean filter" indication. This happens when running any automatic cycle except "air dry". ...
it is proberly lint stuck around the motor and fan resticting air flow to the motor and the motor is shutting down because it is to hot vac out around the motor and inside the cabinet
Jul 04, 2011 | GE Profile DPSB620ECWW Electric Dryer
Shuts down after 1/2 hour drive
The EGR system does this to engine after running a short time. Have it checked out. The valve, solenoid, & the relay for it can all cause this problem
Mar 28, 2010 | 2000 GMC Safari
Keep blowing the ecmb fuse in my 1991 s-10
check your grounds & the fuel pump connections.the ground should run to the right rear of the motor. look at the wires back to the motor on the frame for anything that may have nicked a wire or a rub thru. You have a short and i belive it shut down if you hit a bump. loose or fraid wire some place. Best of luck & keep us posted on your fix.
Mar 10, 2010 | 2000 GMC Jimmy
Diesel generator runs for short time then shuts down. it is a onan 7.5 & runs off of the motor home fuel tank
More than likely a safety control circuit on startup. Either high water temp, low oil pressure, or over rev condition. If not any of the above quite possibly the integratrated generator/engine control circuit board.
Allan
Jul 20, 2009 | Electrical Supplies
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Electrical Supplies Logo
307 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
