75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
The Hi and Low power are built into the radio and is dependent on the frequency/ channel you are on. Hi power is 1 Watt and Low power is .5 Watt. The radio is GMRS and FRS. The FRS are low power and the GMRS are Hi power.
Channels 1-14 are FRS frequencies and Low power.
Channels 15-22 are High power and are GMRS frequencies.
FRS = Family Radio Service.
GMRS = General Mobile Radio Service.
If you have any comments please feel free to leave them here.
Well the CB you have should not cycle through channels like that for sure. It is not a progressive scan. Try messing with the channel 9/normal switch again. In rare occasions that switch will **** to the side just a tad. there is a PCB board inside that is responsible for the channels responding to the channel as the channel knob is turned. This board could be going haywire. If fooling with that switch does not take care of the issue then I would contact the person you got the Midland from immediately and have them get you one that works properly.
Look at Radio Mods or Defcom mods. To clip modulation diode inside radio. Take to Cb shop to Peak&Tune. It may be wound to high in carrier but not audio. Buy you a "Power Mic" at Radio Shack or WWW.COPPERELECTRONICS.COM.
I am sure the OP isn't likely monitoring this, but just in case anyone else needs it... It's a power problem. Try charging the batteries, even though they look like they're fully charged -- or replace with 4@AA batteries.
This only seems to happen on the GMRS channels -- not the FRS ones. The radios come default to transmit at high power (the full 5 watts) on the GMRS channels, but only 0.5 watts on FRS. If you go to settings and change the power on that particular channel you're trying to medium or low, you'd likely find it works with the charge you had problems with.
Recharging or changing to 4@AA batts should get you back up to continuous TX on those high-powered channels.
