Question about Panasonic Lumix DMC-FZ28 Digital Camera
System error: zoom message with Panasonic Lumix FS15 camera
When I turn the camera on in either record or review mode, I get a system error: zoom message after a few seconds, and the camera is inoperable. Then when I turn the camera off, the lens does not retract.
  • smitholi Apr 24, 2010
    hey, I've also got this problem with exactly the same camera. Did you manage to find a fix?
  • hugh killin Oct 07, 2012
    Hi, I had the same problem but I used W5 carcare universal Silicone oil which I bought in LIDL
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
Posted on May 20, 2011
  • 1 more comment
  • dhardy52819 Jul 16, 2011
    My problem with this camera was similar exept I couldn't get the lens to come out. But I fixed it by doing the following and I would say it will work in either scenario. Once you get the lense to come out (in my case it took multiple power cycles while tapping on the side of the camera). take some WD-40 lubricant an carefully apply some to the telescoping parts (Don't get any on the lense). why the lube around the cylinders of the retratable parts then power cycle a couple times. After a few passes wipe off any excess lube and your good to go. The problem is caused by sand/dirt getting in the small crevices and causing friction. The WD-40 lubes and cleans the cylinders. Good luck and happy picture takiing
  • megan_ciotti
    megan_ciotti Jul 25, 2012
    I had the system error (zoom) message on my Panasonic DMC FS15 witht he lense stuck out... applying pressure (as described above) and some gentle twisting seems to have eased it and the camera is working again - hooray! Didn't have to resort to WD40 but will have it on standby...
  • Uschi Sucher-Gruppe
    Uschi Sucher-Gruppe May 22, 2017
    hey James, thank you so much, it WORKED!!! You just saved me a lot of money...
Hi, I had the same problem with my FS15 and I used W5 Carcare Universal
Silicone Oil which I bought in LIDL. I sprayed a little on the telescope then turned it on and of a few times and it is working fine. I think the Silicone is better than WD40 but that is just my choice.
Hugh81
Posted on Oct 07, 2012
I am so glad that I found these comments. My camera started bringing up "system error (zoom)" and it was completely inoperable. I used mineral oil on a Q-tip and swiped it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work it's way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Posted on Nov 01, 2011
  • Annie bananie Nov 01, 2011
    I just posted the above comment but forgot to mention that my camera is the Panasonic Lumix DMC-ZR1 model.
  • Nitu Mehta
    Nitu Mehta Oct 27, 2013
    thanks for your comments, I got a same problem as my son threw the camera accidently... I cleaned the edge of the lens with cotton and pressed gently few times, it made a click sound and is back to normal...phew, got lucky :-)
I have this problem too. Was there a way to fix it???
Posted on Nov 15, 2010
  • Randal Oct 13, 2011
    My wife had exactly the same problem with her lens not retracting and the error message on the screen.
    I tried the 1st fix ie pushing the lens in manually - It clicked and retracted but the error message was still there and the lens would only come out half way.
    So I tried putting WD40 around the body of the lens and after 2 or 3 goes the lens came out fully and all sytems were go again. The error message also disappeared from the screen.
    Good old WD40
How to slove system error(zoom) of my panasonic lumix dmc-fs15
You can't. it is cause by something blocking the gears or the lens being knocked to the side. Here is the online service form
http://www2.panasonic.com/webapp/wcs/stores/servlet/RequestCenter?storeId=15001&catalogId=11017
Jul 01, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Oct 08, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
I have an FS15 and get the error message, 'system error zoom' the lens is not centred and does not retract. The camera has not been dropped and is c15m old.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Have a Panasonic DMC-FS15 and get message saying "turn off and back on" followed by "system error (focus)" Have tried taking battery out for length of time and making sure charged, blew...
I have this exact problem. I note, your issue is happening at the same time. Weird.
Tried a variety of other "fixes" but none seemed to solve this issue. Thoughts?
jeremy.wolf@gmail.com
Dec 03, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Sep 19, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
6,920 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
