Question about Dell Inspiron 1420 Laptop
Both boxes are in a cabnet and are stacked on top of each other. The screen on my TV says that my box is over the safe operating temperature limit. Iniial box temp is 150, safe temp is 122
  • 2,229 Answers
I have no idea what boxes you are talking about, but if you are getting a warning about heat--pay attention to is and unstack the boxes and get some ventilation where it's needed.
It is generally bad practice to stack electronic components--they generate heat and heat tends to make their operation flaky.
You could separate them and place a fan in the space to cool them.
Posted on Jul 20, 2009
Replaced thermostat and element on hot water heater now fuse box is getting hot and smelling like it is burning.
you have a short . check with a meter = If you dont know what your doing get electrician - you will have a fire,
Dec 31, 2013 | American Standard 9075.120 Safe-T-Heater...
Sound problem with Standard (CRT) Televisions along with set top box
From your description, it is likely that there has been a failure in the TV sound system.
Dec 27, 2013 | Televison & Video
My accer aspire 5745 laptop hang hw 2 restart curser also nt movable
1- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
-Limit programs that run at Start up Limiting programs that run at startup might help you to fix your computer freeze problem
-Click on the Start button
-Type msconfig into the text box then press Enter to locate msconfig You will be prompted system configuration page
-Switch to Startup tab and Remove the check from the box programs that you do not want to start up with the operating system
-press Apply and OK button
If this didn't help you then simply get the Intel Software Partner RegInOut to fix registry issues to make my PC performance reliable & fast.
Jun 11, 2013 | Computers & Internet
Dell 5720
download the software diagnostic coming with the computer and pass go www.dell.com give your service tags.
Use the antivirus+antimalware+scandisk
God bless you
Jun 06, 2013 | Computers & Internet
I cannot change my screen resolution
Boot up in safe mode and see if you can change the screen resolution. If not you are being limited by your graphics card (video card) and driver.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. See if you can change the screen's resolution.
If you can't change the screen resolution, try downloading and reinstalling the video driver.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
May 24, 2012 | Dell Computers & Internet
14MG135 4:3 14" Television 14 in. Is this a
No this is not a digital tv. You will need a converter box/set top box. I am posting the specifications. Where it says tuner it would have to say atsc and/or qam for it to be a digital television
Product description Product Identifiers Brand Thomson Model 14MG135 MPN 14MG135
Key Features Screen Size 14"
Technical Features Screen Type Non-Flat Screen Aspect Ratio 4:3 Built-in Tuner NTSC, PAL, SECAM Adjustable Color Temperature Without Adjustable Color Temperature
Connectivity Front Input Connectors Audio (RCA) x 1, Composite x 1 Rear Input Connectors RF x 1
Audio Features Number Of Speakers 1 Speaker Power 1 x 3.5 Watt Audio Type Mono Subwoofer Without Subwoofer Audio Leveler Without Audio Leveler
Miscellaneous OSD Languages Danish, Dutch, English, Finnish, French, German, Greek, Italian, Portuguese, Russian, Slovakian, Spanish, Swedish, Turkish Parental Control Proprietary Sleep Timer With Sleep Timer Remote Control Standard Additional Features Headphone Jack
Jul 19, 2011 | Thomson 14MG135 14" TV
I need to know thermostat location on maytag performa dryer
The operating thermostat is located on the blower housing behind the front panel, however the thermal fuse/hi-limits are located below the top attached to the heater box. They are more often the culprit as is the element in those units.. Check the exhaust path from the lint screen out to ensure a clear 4" path the entire length, as blocked ducting will raise internal temperatures and also cause those components to fail..
Have fun, and best of luck,
Thanks,
Chuck
Feb 22, 2010 | Maytag PYE2300AY Electric Dryer
My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Aug 15, 2009 | Philips Televison & Video
Welcome screen is not appearing
Turn of the computer and press F8 every few seconds.
A box will pop up with a list of choices.
Choose Safe Mode with Command Prompt
Let me know when you get this far.
Feb 25, 2009 | Microsoft Windows XP Professional
Dell Inspiron 1420 Laptop Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
