Question about Motorola Mobility RAZR V3
Time display I just purchase the MOTOROLA V3 RAZR and everything works fine except the time display. It randomly displays the incorrect time, but the date is correct. Occasionally the time does display correctly, but this is the exception
  • Anonymous Mar 28, 2014
    How do you extend the display time light in camera mode?
    Problem Solver:
  • 4 Answers
Check the network time settings. If the phone time is "Set by network" maybe the network time servers are messed up. Set the time on the phone manually and see if the problem is fixed. If the phone is already set manually see if setting it to Set by network will force it to keep correct time, but the internal clock should be more stable than that. You may need to get a replacement if these tricks don't work.
Posted on Nov 20, 2007
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Display time and date
Go to your phone's "Time & date" settings and select "show", u might have your date and time hidden this time. And more thing, set the time and date first, some phones displays time and date automatically after setting...unless the user choosed to hide it...good luck! i hope this solution solved your problem.......
Oct 09, 2008 | Motorola Mobility RAZR V3
Problem in display.
   if u had operated ur razr with wet or oily hands, then it ll cause display problems...any internal display circuit would have got damaged because of take it to d nearest service center immediately to prevent further problems..
good luck
Jul 04, 2008 | Motorola Mobility RAZR V3
Razr screens
uasdriver - have the flexcable replaced on the phone,this will take care of the display issue that you are having.
Guest - the flexcable or the lcd needs to be replace , take the phone to a mobile service center and have them replaced it.
Mar 20, 2008 | Motorola Mobility RAZR V3
How to display the date on my home screen
just press the menu botton'
go to setting
sellect initial set-up
and select time and date.
you can now set the time and date of your fone...
Jan 05, 2008 | Motorola Mobility RAZR V3
No date display
yep i have the same problem too. no date display. it displays the date on the outer screen when i flip the phone shut. but not on the main screen when it is open.
Jun 18, 2007 | Motorola Mobility RAZR V3
Motorola Razr V3M's external display not showing wallpaper. iTunes help too!!??
As far as I know only razr v3i has i tunes. as far as the external display not showing your wallpaper as the internal screen i'm not sure except if it dosen't show the time and stuff on the external display your screen's connector for your display may be loose if so thier should be a solved problem for that.
Mar 12, 2007 | Motorola Mobility RAZR V3
Motorola Razr V3, no autoupdate for date and time?
The only way you're going to fix this is if you update your firmware. Check for some help on that.
Feb 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
153 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
