Question about Polaris Pb4 - 60 Booster Pump
Pump is 3 years old and just started to make a loud whining sound.
    Sergeant:
  • 199 Answers
Sounds like a berring is going out. time to get another one not worth the cost to fix sorry i have taken three apart and what a pain. take it to a motor parts repair place and or pump to a pool repair place and see
Posted on Jul 20, 2009
I have a Hayward in ground pool pump with an AO Smith model# k48m2n111. It's 10 years old now but yesterday it stopped working and just whines real loud when i start it . Could it be a quick fix? Is it...
Hayward pumps are poor quality. You're lucky to get ten years. In 4 years I've needed the motor replaced twice and the pump repaired. The motor is starting to whine again. Just a matter of time before it fails. Do yourself a favor and stay away from Hayward.
Oct 06, 2014 | Pool & Spa
WHIN NOISE
Are you sure it is not the transmission pump or torque converter
No one can guess at noises-need to have the vehicle to check
that out
Have a dealer weigh in- IF- it is still in warranty
When you say loud & the vehicle is only 3 to 4 years old
I would stop using it in a hurry until that issue is solved
Jul 16, 2014 | 2011 Hyundai Santa Fe
Whinning noise when engine is off
Whinning Causes
The whining noise you hear coming from the power steering pump is one of three things. The first is more of a loud "hush" than a whine; this is the sound of fluid rushing through the bypass valve when you turn the wheel all the way to one side or the other. Sometimes the bypass valve malfunctions or doesn't open all the way, causing pressure to back up in the pump and cause your engine rpm to drop. The second and third causes result from cavitation -- vacuum pockets created behind the rotor's vane blades as a result of extremely high pump action -- or air in the lines.
Nov 24, 2013 | 2003 Mini Cooper
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Start pool up this year pump is louder makng whine noise, works fine and it is not getting hot Is the pump going
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
May 22, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
3 year-old Goodman compressor/heat pump terribly loud @ start
I don't think this problem (btw I agree 'from a far distance' with the Hvac guy) is inherant to Goodman, after all the compressor (that is in the unit) is one that if found in other brands too.
Of course the compressor is under warranty so there's no charge for it - but - $800 to change out the compressor (and that's the proper fix) is a 'bit' high - you possibly could save a few bucks by getting some other estimates.
good luck!
May 09, 2010 | Goodman CKL60AR60 Air Conditioner
Without being there to see it and have only your description in front of me, it sounds like the fan blade could be out of balance.......but it sounds more like a loose fan blade hub. Most Goodman units offer a minimum 5 year parts warranty. The Labor warranty is questionable, but the installing contractor or the Goodman Distributor should be able to give you that information. Of course this would cover manufacturer problems and not physical damage. As far as a history of this problem with Goodman..........I've seen it with every brand. If there is a problem getting it under warranty, you might be able to purchase the blade yourself. Before replacing the fan blade, I recommend disconnecting the motor wires from the contactor, tape off the ends and remember exactly where they were attached.....then start the unit to see if the noise is still evident, if so, it's probably your compressor. I recommend a certified repairman....not the one that quoted you $800.00. If you hear only the compressor start up and not the loud noise you are discribing, then try replacing the blade first.
I hope you find this information to be very helpful to you. :-)
Mar 16, 2010 | Goodman CKL60AR60 Air Conditioner
My challenger 3/4 pump has started to sound louder and louder.
Replace the motor bearings before they fail completely and ruin the motor.
Jun 07, 2009 | Pentair Challenger 3/4 Hp In Ground Pool...
Polaris Pb4 - 60 Booster Pump Logo
461 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
