Question about HP LaserJet 3600n Printer
I pulled out a paper jam and a part fell out that is used to guide paper. Does any one have a schmatic so I can properly reinsert this part?
  • 202 Answers
Try googling feedroller.com and see if they have the service manual.
Posted on Jul 20, 2009
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Why does paper go in crooked and then jams
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 09, 2012 | Lexmark X2500 All-In-One Printer
Says paper jam and there is no paper jam
Feb 19, 2012 | Lexmark X2600 InkJet Printer
Printer paper pulled half through then stops
Leading cause of paper jams or misfeeds is debris or foreign objects that fell accidentally in the paper feed area. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any obstructions.
Also, try to open the printer cover and make sure the paper path is free from foreign objects or debris.
Re-insert your cartridges and make sure they are properly seated in the carrier.
Dec 23, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper jam but there are no paper jam
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem: 1. Remove the sheets of paper from the feeder.2. Grab a flashlight and look inside the feeder for any debris or foreign objects.3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.5. Check the cartridge area for any obstructions in the paper path.6. Close the printer cover.7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Dec 08, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have a 6600 printer I am getting a paper jam though this no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 29, 2011 | Lexmark C533DN InkJet Printer
I can't get the paper feed to work properly. Printer is telling me to load paper when it is full of paper Printer is asking me to clear paper jam when there is no paper jam Printer is just not...
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper feed light is flashing yet there is paper loaded.
It could be indicating that there's a paper jam, cartridge problem or carrier stalling. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any debris that may have accidentally fell into it. If none, open the cartridge area and remove the cartridges. Make sure there are no obstructions in the carrier's path. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper and check if printer is working properly now.
May 05, 2011 | Lexmark X2670 All-In-One Printer
Paper from tray 2 starts to load then you here a high pitch squeak then paper jams and gives error code 241.09. Pull paper out of bottom tray reinsert paper then is fine till it jams again. Any thoughts.
If its some thing that just started, then you may want tocheck if you are using a new paper manufacturer. Sometimes frequent jams arecaused by thin paper.
Mar 02, 2011 | Dell 5210n Laser Printer
Connon ir 1210 copeir paper jam but i can not see that papper size A5
the paper may not have come out the paper tray and this is causing the error check the paper tray settings and the paper side and end guides have the paper held in properly.. if you pull the tray out and press the paper down the guides should be touching the sides and end of the paper this will allow the paper to be fed properly..
Jul 13, 2010 | Office Equipment & Supplies
HP LaserJet 3600n Printer Logo
106 people viewed this question
Seeker5211
Seeker5211
