The motor works because I can select any speed and it will spin-but when I put the pitcher on it wont turn the blade. Do I need a new blade?
Comments:
Jul 20, 2009
- hello- thank you very much! The shaft in the base housing does spin. The shaft of the blade is not spinning. I have tried pliers, cleaning it really good - even wd40!!! I'm in serious need of a blender so I will just go buy one at walmart while I wait for a part from the mfg. Thanks again. BTW- I have had the blender for about 3 years- just thought I would add that bit of info.
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
The blades don't rotate anymore in the black plastic which connects the base with the glass and...
(More)
The blades don't rotate anymore in the black plastic which connects the base with the glass and which consists mainly of the blades and a whiteish rubber. Any ideas? B.t.w: There are no spare parts available anymore.
the cuisinart blender motor works and turns but the cutter blade is ciezed up and wont turn...how...
(More)
the cuisinart blender motor works and turns but the cutter blade is ciezed up and wont turn...how can i fix this problem?
