Question about Electrical Supplies
Diesel generator runs for short time then shuts down. it is a onan 7.5 & runs off of the motor home fuel tank
The 40kva diesel generator runs tof a 5minutes then cuts off the power to the loads, and a res indicador flashes.so what could be the problem
Posted on Oct 25, 2013
More than likely a safety control circuit on startup. Either high water temp, low oil pressure, or over rev condition. If not any of the above quite possibly the integratrated generator/engine control circuit board.
Allan
Posted on Sep 10, 2009
Onan marquis 5000 model # 5bgmfa26105f runs for a few minutes and shuts off. let it cool off and it will start again. whats the problem?
There are many possible reasons from stator output voltage to sensing, to fuel to control boards. A good place to start (as the unit does run) would be with the fuel system, if it has sat a long time it won't help. Also the fuel filter. try conencting to an external fuel tank versus the vehicles, as sometimes pick up tubes in main tanks can be an issue. Also check the correct oil level and viscosity / and oil pressure switch. Failing that I recommend a service center, as there really are so many causes, I cannot list all on here.
Aug 01, 2013 | Watts Onan Portable Generator - 5000 ,...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
The engine has low oil level shutdown. It may be the reason for stopping.
Use the welder only at level condition. Check the oil level, before every start.
If no result, find and check the oil sensor contact (if possible replace with good to check). Try with disconnected and shortened contact prior to buying a new one.
Other possible reasons you already checked
Aug 05, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Jul 23, 2009 | Watts Onan Portable Generator - 4000 ,...
Genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Jul 20, 2009 | Electrical Supplies
Onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Jun 07, 2009 | Watts Onan Portable Generator - 4000 ,...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Electrical Supplies Logo
230 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
