Question about Vacuums
The switch on our Hoover Windtunnel vacuum cleaner is not working. I have located the replacement part on your website...part#Ho-28161067, I've removed the wires from the switch. Is there any trick to actually removing and replacing the switch itself? It seems to be in there rather tight.
  • 97 Answers
No, follow the directions to replacing the switch and you should be good. if you got the kit then splice the wires and replace them with the wires profied and the wire nuts, you should be good.
Posted on Jul 20, 2009
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
What is the on/off switch # for Hoover Widepath model U5140-900. I cannot find it on the web.
part # is 28161067. We have them in stock. you can call me direct 440 234-0845 or visit my website www.acevacuums.com
Mar 06, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My vacuum died. It won't turn on. It is not the outlet. Is it a blown fuse? How do I replace the fuse? Where does it go? This vacuum is a little over 2 years old. My older Hoover WindTunnel STILL works and...
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Jul 09, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
The on off swtich doesn't work on our hoover windtunnel vaccum cleaner. Can it be repaired?
If its just the switch then by all means it can be repaired or replaced. If it needs replacement and the part is not available, you could replace it with a generic switch which may need some modification. Alternatively you can bypass the switch with the wiring and turn the machine on and off at the wall outlet.
Best wishes,
Graemevm
Jun 06, 2009 | Hoover Windtunnel Supreme U5280-900...
Hoover S3639 Windtunnel Vacuum not on after burning smell
how old is it ?maybe the motor went south.take the cover off and see if you see any burn marks ,maybe you can narrow down the burnig smell.i don't charge people for helping i just enjoy helping.314-628-9153
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bad on/off switch hoover U6476
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Off/on switch does not work
The on/off switch in Hoover Windtunnel upright vacuum cleaners is operated by a lever in the handle assembly.  remove the two screws on the back ovf the vacuum and see if the lever has bypassed the switch assembly.  if so, re-assembly should fix the problem.  It is also possible that the switch activating lever has broken.  If so, replace the activating lever.
Oct 24, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Vacuums Logo
367 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
