I have a magnasonic model dvd800-4 the power comes on .Power button lites up but nothing else happens.
  • 1 more comment
  • knut748 Jul 20, 2009
    I cannot see a reset on this machine is it inside the unit? Nothing works on this except the lite on the power on switch.
    My magnasonic dvd player modeldvd800-4 is not coming opening but the power lite on the start button is working.
    Art
    I checked the fuses ok unpluged five minutes and repluged a flash on the led screen but will not power up .where do I get a schematic on this thing .I can check the voltages i am an electrician.
    Art
  • 3,037 Answers
Well if there is no dvd in there and the door won't open then either your door motor is burnt out (most likely), you have a loose connection, or the control board went bad. If it is under warranty, then get it exchanged or fixed. If not, first try opening up the cover and check to see if voltage is being applied to the motor with a volt meter which can be bought at any electronics store like radio shack. If you don't feel comfortable with diagnosing it yourself (you can get shocked and wreck stuff with the power on if you don't know what you are doing), then I recommend taking it to a place like Radio Shack and having them fix it or find someone with electrical expertise. One simple thing you could try is a quick reset by unplugging it for 5 minutes and seeing if it then will work. Let me know how this turns out.
Benjamin
Posted on Jul 20, 2009
  • Benjamin Patri
    Benjamin Patri Jul 20, 2009
    There is no readily available schematic, you would have to go through the manufacturer and see if they will provide you with one. I hope this helps.
    President:
  • 2,923 Answers
You were saying that it's not responding? Can you open the DVD tray? Can you go to the Menu? Please provide more information.
If it's not responding at all, try disconnecting the DVD from the power outlet and leave it disconnected for about 5 minutes. Then power it back ON.
Or check if there's a reset button on the player itself, if yes, hold it down for 30 seconds the turn off the player.
Try this first and hope it helps.
  • Melvin Ramos
    Melvin Ramos Jul 20, 2009
    If you couldn't find the reset button outside, then definitely the reset is inside the player.But, it's not a button, it could be a jumper that would restore the player into the factory default. If the player is under the warranty period, I would suggest NOT to open the player because it would VOID the warranty
    Try power cycling first the unit by disconnecting it from the power outlet and leave it disconnected for 5 minutes. Then, if you get the same problem, it's better to contact the manufacturer. It's hard to tell which jumper would reset the player.
T.V. wont come on although the red lite is on when plugged iun and the blue lite comes on when you hit the power button the screen does nothing it is a haier 32 inch LCD model L32F1120
Hi Judy
How old is your unit? but any way the problem of your unit is probably leaky capacitor. kindly check on the internet how leaky capacitor looks like.
Jan 19, 2014 | Televison & Video
No power
There are quite a few possibilities here. Do you leave your computer on while you're not home? If so, it's possible the computer overheated. If that happened, most likely you processor is damaged, and will have to be replaced. There may have been a power surge, which could have damaged the power suppply or the motherboard. It does nothing when you push the button? There's also a remote chance the switch is merely broken... though I can't say I've ever actually seen that happen. If it does absolutely nothing, it's most likely the power supply, however. If the motherboard or processor were bad, it would probably beep when you tried to turn it on. Not definitely, but probably.
Sep 07, 2007 | Gateway 500GR PC Desktop
My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
Dec 19, 2012 | Philips 51PP9200D Television
How to unlock magnasonic vcr/dvd 833-2 combo
If the shipping lock is on, on your Magnasonic DVD833-2, hold the POWER button for 8 seconds. The factory password for parental control is 3308. For the factory manual here is the link http://magnasonic.com/discontinued/manual/DVD833-2_Eng.pdf
Oct 22, 2011 | Televison & Video
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
My sons ds lite got dropped (not by him) and now nothing happens.
With some soldering skills, this could be repaired. Other than that, I would say that it's time for a new one.
Apr 15, 2009 | Nintendo DS Lite
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
My LG Flat Screen won't turn on.
power board issue or capacitors on the power board have blown this happens with electronics, service center will be required to replace the board or if you know some one who solders electronics they could do it also. to keep this from happening again buy a ups backup power supply which will condition the power to the tv and other components and save you allot of time and trouble later.
May 26, 2008 | Televison & Video
Problem with my dell dimension 4600
Does the hdd lite come on? cd lite come on? The blinking lite on the power is an indication the bios or power supply is having trouble. strip the unit of all devices except hd, kb and use the vga built in video. Remove the ram also. restart and see what happens.
Dec 08, 2007 | Dell Dimension 4600 PC Desktop
Code for Magnasonic TV
I have magnasoni TV 14`` and I have Unversal remot RCA in need some help for codes thanks
Nov 06, 2007 | One For All URC-4330 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
