Question about Plumbing
Hi..I'm replacing the seal in an NG series Monarch pump, coupled to a 4-cylinder Wisconsin engine. I can't get the pump casing apart, is this from rust or something I've missed?? All the bolts are removed. Thank you..Russ
  • 832 Answers
All the bolts are removed.... Put a kerosene/WD 40 around the pump lids, and let it stay for day. After a day, use a hardwood hammer to take it off. Let us know by e-mail for the results as well as for further assistance.
Posted on Oct 27, 2009
Seeking a good place to find info on 4 cylinder wisconsin gas engines
You might try your local Ditch Witch dealer. The older trenchers used an air cooled 4 cylinder Wisconsin engine.
Oct 04, 2014 | Cars & Trucks
No pump pressure when engine is running
Firstly make sure you have water entering the pump and that the inlet filter is not blocked. If ok then you could have a problem with the bypass/unloader valve in that the seals in that have probably gone. It is the compressed spring with nut on the top. You can take it apart (normally) and the central spine (which the nut sits on) will have a tapered bottom with an o ring on it. You can either replace the o ring or get a new valve. Before replacing check the pump actually runs first in case the drive coupling has broken. The only other problem will be the pump valves or seals.
If you do replace/fix the unloader valve you set it to the correct tightness by depressing the pressure gun and turning the nut until the bypass water stops. Continuing to tighten beyond this point will shorten the pumps life.
Mar 13, 2014 | Honda Garden
TOYOTA CONDOR 2RZ IS OVER HEATING WHAT IS THE PROBLEM
Hi I have a 2005 stallion panel van ... same as condor also 2l petrol. Also had some heating issues here is my experience. It could be 1. malfunction viscose fan 2. broken thermostat 3. blocked or worn radiator 4. Water pump seal leak or corroded or loose impeller. 5. blown cylinder head gasket 6. cracked cylinder head.
In my case the water pump was leaking slowly as a result of the inner seal creating an airlock in the water system which in turn releases the pressure in the system and lowers the boiling point of your coolant.. If this is the problem you would find that with periodic checks your system will need some water. Look on top of the pump behinf the pulley is a hole which looks somewhat like a missing bolt. This hole will drip water if the inner seal has gone. Look for a telltale sign that water has run out of this hole like a sediment line from the hole down the side of the pump. If so replace the pump there is no other repair even if the rest of the pump eg bearings look and feel perfect. Just a hint for this job the radiator needs to come out and all the belts off etc. so while the coolant is out replace all the belts and thermostat. Thermostat housing is on the right side of the engine just follow the water hose. Hope this helps. Good luck. Ernest
Sep 16, 2013 | Cars & Trucks
Our sewer pump loses prime, when we manually re-prime it will pump but constantly loses prime.
pumps that continually loose prime 4 sure have an air leakage problem two places that most pumps can leak air into them are (1) input shaft seal
(2) check valve
the check valve is by far the easier of the two to replace id start with that one first some waste water pumps have two check valves on them one on suction line and one on discharge line (if over 10 feet high)
Jul 31, 2011 | Monarch Pumps BE-S75 Wastewater Pump...
My lexus ls 400 model 1991 when start gray smoke ocurr for few second then disappear
the smoke is from engine oil, it is caused by leaking valve seals , after the engine is shut down for the day oil is leaking past the valve seals and getting into the cylinders then when you start up the engine the oil is burned off, this is a common problem, and there is a couple of things you can do to help the problem with out taking the engine apart and replacing the seals, try this first at your next oil change add some Restore to the engine oil it will soften the seals and give them a little more life, if this does not cure the problem after a few 100 miles then you will need to have the seals replaced, and this is a costly repair, but you could just live with the smoke it wont hurt any thing just keep an eye on the oil
May 17, 2011 | 1991 Lexus LS 400
Needs a new timing belt how much to have it replaced
About $300 in parts (to do the job right)
and about $300 labor total $600 moost places will charge from 6 00 to 800 a real thief $ 1000.
Remember to do the job right Tbelt, water pump, 2 tensioners, two oil pump seals, cam and crank seal, valve cover gasket.
Mar 27, 2010 | 1989 Toyota Camry
Ive got a 13b series 4 rx7 needs seals done
yes! its the best time! and only time since the engine will be apart.
Feb 19, 2010 | 1989 Mazda RX-7
Torque waterpump bolts mercedes benz
Torque wrench settings Coolant pump to crankcase/timing cover: 4-cylinder petrol engone 10( Nm) or 8( lbf ft) 6-cylinder petrol engine 23 (Nm) or 17 (lbf ft) Coolant pump to housing (Diesel engine)10(Nm) or 8 (lbf ft) Coolant pump to belt pulley: 4-cylinder petrol engine 15;11 6-cylinder petrol engine 10;8 Diesel engine 15;11 Cooling fan to electromagnetic/viscous MB(try not change pumu but viscous coupling Mercedes became cool) coupling: 4-cylinder petrol engine 25;18 6-cylinder petrol engine 10;8 4-cylinder diesel engine 25;18 5-cylinder diesel engine 10;8 Viscous fan coupling to coolant pump/bearing body 45;33 Electromagnetic coupling to coolant pump / support bracket 6;4 Radiator drain plug 2;1 Thermostat housing to cylinder head (4 cylinder petrol engine only) 20;15 Alternator mounting bracket bolts 45;33 Cylinder block drain plug 30;22 Automatic transmission fluid cooler unions 20;15
Aug 09, 2009 | Maisto Mercedes Benz Slk Diecast Model Car...
My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Jun 04, 2009 | 1974 Yamaha DT 360
1982 240 volvo
Your engine does NOT have a carburator. Unless the engine was replaced by an earlier one, 1982 Volvo's were fuel injected.
This is an older fuel injection design that is a "constant flow" type system ie. there is a constant spray of fuel while the engine is running. Newer fuel injection systems, including Volvo, are "demand" type systems where fuel is only sprayed through the injectors when the engine electronics signal it to do so.
In any case, this older system is very sensitive to vacuum leaks. Check all your hoses for splits, hardening or connection looseness. Check the seals on each fuel injector (there are 4, one for each cylinder). If they are hard or cracked, replace them.
The later problem was the case on my 1981 240 which had the same problem. New fuels injector seals and the car runs perfect.
Good Luck,
Dr of Motors
Sep 09, 2008 | 1982 Volvo 240 Series
Plumbing Logo
63 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
