Question about Panasonic PT-40LC12 40" Rear Projection HDTV
When hcr4755 light flashes 5 times
When Unit is plugged in the light just right of the power button flashes 5 times. Unit will not turn on at all. The (what appears to be the power supply) (Says in-line Filter on it) The area around the board that has the Thermasistor looks like it got very hot. I checked the thermasistor for continuity and I get 0 ohms. Cannot see any other issues with TV. Please Help.......
  • 59 Answers
SOURCE: panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Posted on Oct 23, 2007
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
STOP THE PRESS!! I FIXED MY TV for a whopping $26.
I took a wild shot and purchased two STK392-110 convergence amplifiers from http://www.electronix.com/. They ship fast, placed my order on Tuesday evening after coming here and placing my comment. To my suprise the parts were in my mailbox on Friday. The parts were actually $12 but I also picked up a iron and a solder sucker.
So rarewish4us, If you're in the South Florida area I'd be more than happy to take that "JUNK" off your hands. LOL
If I were you, I'd give it a shot before you junk it.
Good luck,
Howie
Posted on Feb 09, 2008
SOURCE: Panasonic MODLE PT53TW53G led code flashes 3 times convergence problem
I replaced the ic's and still have the same problem.
Posted on Sep 11, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
asnowman
  • 788 Answers
SOURCE: my Panasonic PT-53TW53 53in TV won't turn on..
Your symptoms sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current. This is indicated by the flashing red light on the front of the set.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 15, 2009
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
Reset power
To do partial Reset.
1.Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit.
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer won't print flashing green light
Please follow the steps given below and check the functionality.
Bypass the surge protector ====================
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet and see if the message still appears.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
May 26, 2009 | HP Office Equipment & Supplies
Switch printer on,just get grinding noise on right hand
try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Sharp LC-32D43U
This unit probably has a bad power supply. It may also be shutting down because if this unit has recorded 5 lamp errors it goes into shut down. To eliminate lamp errors you can force the unit on in the service mode and look for lamp errors. To do this, you unplug the unit, and while depressing the volume up and channel down buttons at the same time, plug the unit in. Hold for 1 second and release. The unit will then power on and a small k should appear on the screen. If this does not happen then there is definately an internal failure that will require a sharp auth. service center. If the unit does come on with the k, use the remote and press the channel up button. This will produce a menu on the screen and you will note on line will indicate lamp errors. On the right side of that line will show the # of lamp errors. If it reads 0, lamp errors are not the issue, however if it reads 5, you can highlight that line by using the channel down button. Then use the curser right arrow to select the error and then again to reset them. Once the lamp errors have been reset to 0, unplug the unit and wait at least 25 seconds before plugging in. The unit will now power up normally and this may cure the problem for good. If this process corrects the problem and it occurs some time later or right away that will be an indication that either the unit has bad backlights or inverter has failed and will again require service.
Feb 07, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
