Question about Proform Crosswalk 500 Treadmill
Problems with my pro form 540 treadmill
None of the buttons work except for the #1 and #4 buttons. The machine will only turn on and off by inserting and removing the key.
  • Bianca Jun 26, 2012
    My problem is that only the ifit button and the decrease in speed button work, nothing else. I've tried cutting through the piece of clear plastic with 8 wires as instructed and fidgeted with them but nothing has worked. help please?
So after reading the post from EricLaw, I wanted to clarify his solution because it also worked for me. When you open up the console, you will see the membrane (it actually says membrane inside very small) and the connecting wires to the membrane is actually a wide flat plastic with some stripes embedded in the clear plastic which can be easily detached from the membrane (looks like masking tape w/ stripes). These stripes are how the touch pad on the console talk to the membrane. I then took scissors and cut slits between each stripe (cutting only the clear plastic part of the plastic tape) so that I could leave a strip out of the membrane. I played around leaving different strips out until the right strip was left out. If I recall correctly, I left the 5th strip out and the key pad now works entirely EXCEPT the speed 1 and 4 which were the only keys working until I did this. Hope this helps.
Posted on Aug 19, 2010
  • 7 more comments
  • timandnat Oct 21, 2010
    Heck Ya! That was the ticket! It was the 6th wire from the left on my treadmill! Never would have got that fixed in less than 5 minutes without your help! You kick *** and I owe you a BEER!!!
  • bogie77382 Feb 21, 2011
    Our problem was that only the iFit button worked, nothing else responded. I opened up the console, and found that when I unplugged the ribbon on the left side (the side with the iFit, program, incline control and stop buttons) all the buttons on the right side worked. So I split the embedded wires on the ribbon and bent them back one by one. The sixth one down was the bad one. It all seems to work now.
  • Strapscan Jun 22, 2011
    OK, Here's a new twist. I had this problem before and this thread fixed it for me. Now the machine is doing it again except this time only 1 & 4 are working. Last time it was 2 & 5 I think. Now I started trying to leave 2 strips out and it seemed to work but when I went to put the console back on it stopped working. Does anyone have any ideas? Does it make sense to leave 2 strips out? Do you think I was on the right track and maybe something moved slightly when I put it back? I can't get it to work again. argh! Thanks for any and all help!
  • aawalton Jun 22, 2011
    I'm definitely no expert but my only recomendation is to play around with the strips trying different combinations, then seeing what effect it has. Would even recommend writing down the effects to hopefully save you time from repeating steps unnecessarily. The 1 & 4 issue is the main problem everyone is having so if the steps already laid out is not working, make sure to post the resolve here when you figure it out and DON'T GIVE UP!
  • Junirodrig70 Apr 17, 2012
    Just fixed my neighbors treadmill thanks to your post
    Just fixed my neighbors treadmill thanks to your post it was quick and free.
  • ramcclure
    ramcclure Apr 06, 2013
    I just fixed my wife's ProForm 590 LT by following this. It fixed most of the buttons and it is way better now. Thanks everyone!
  • Leo123 Aug 23, 2013
    Thanks a lot for posting the solution. Our tread mill broke a few years back and it works intermittently. Now I applied the solution and left out 5th wire. As every one mentioned now all buttons except 1 and 4 work, winch I can live with.
  • Heather Herrera
    Heather Herrera Nov 06, 2016
    Ours was the I fit. Once I unplugged this panel the entire panel worked again. Thank you so much.
After disassembling the console, it’s clear that the problem is there’s a stuck line in the membrane keypad. I wasn’t able to surgically fix that, but I determined which of the 8 control lines was stuck and simply unplugged that one. So, now the 1 and 4 button don’t work at all, but all of the other buttons do—including the increase/decrease buttons, which allow me to easily get to 1 and 4 anyway. That was sorta fun. The ProForm folks aren’t willing to replace/sell me just a membrane keypad—they will only sell a whole new console (>$300). Rats.
Posted on Apr 06, 2010
  • aawalton Aug 19, 2010
    Please tell how you determined which of the 8 contol lines was stuck and how you "unplugged" it as the wires appear they would need to be cut, not unplugged. Once I cut a wire, I don't want to make matters worse if it is the wrong one.
  • EricLaw Oct 07, 2010
    The pad attaches to a control panel using a plastic ribbon connector which contains ~8 control lines/wires (which you can see through the clear plastic). I simply cut the clear plastic parallel to the wires so that I could insert the wires into the slot on the board at will. I then plugged in combinations of wires, tried them to see which buttons work, and at which point adding a new wire caused the buttons I cared most about (e.g. /- speed) to stop working. I then left that line unplugged.
My profom 540 just stopped working and only 1 and 4 keys work. Last night, I tried the solution mentioned above and now all the keys work except the 1,4 and 6 keys but I can use the +/- keys to get these speeds. I am going to try to use the iFit function and see if it works. The solution is to remove the back cover, then remove the screws that attach the panel so I can have access to the back of the panel. Then I detach the locking piece of the white connector that receives the ribbon cables, then, remove the ribbon and cut along between the contacts and bend the 5&6th cable, then insert the rest of the ribbon leaving the 5&6th cables out and snap in back the locking piece, put the panel back and insert the key and for some reason everything works, except some of the keys. Then screw back the panel and the back cover and you are all set.
Posted on Jan 13, 2014
I had to leave the 5th and 6 wire out of the harness and the treadmill works perfect.
Posted on Aug 18, 2012
How is it that you even unplug clear plastic that is attatched to the membrane?
Posted on Jun 26, 2012
How does this happen all at once to everyone? I just experienced this #1 and #4 being the only functioning buttons on my Proform 540 for the first time tonight. How exactly to you find the control lines and what is the procedure for "unplugging" the one that is stuck? From what I see, they are all soddered into the main plug housings. Or am I looking in the wrong place?
Posted on Aug 13, 2010
Wow, It must be a bad part that is going out. I was searching on here for what could possibly be wrong with my treadmill. It does the same thing. Just the #1 and #4 work. I hope I can open it up and fix it like you have suggested. Thanks. I will make sure I contact Proform and let them know that it needs to be fixed for the future people buying this treadmill.
Posted on Aug 10, 2010
  • cardocr Oct 07, 2010
    I also have the same exact problem - that is only the 1 and 4 keys work. Sometimes I can push on the membrane above the ifit button and get all the other keys working again for a while but they'll eventually stop working again. Seems like this is a common defect with this treadmill. I'll have to see if if I can use the technique mentioned in this tread to get all the other keys working. I certainly could live without just the 1 and 4 keys.
My proform 540 only turns on and off with the key and works in # 1 and 4, sounds like the same post as Aembrdery in July. any solutions
Posted on Mar 04, 2010
4 Suggested Answers
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Posted on Apr 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
Its Clicking none stop,and wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 30, 2012 | Philips Magnavox 52MF437S/37 52 in. LCD TV
My jailbroken ipod wont turn on
5.Wait 10 seconds.
Step
Thanks
Jul 29, 2012 | Apple Ipod Touch 4
I need to know where the batteries go
Dear Sir: I will help you, please do the following step: Instructions Things You'll Need
  • Power supply
  • Standard screwdriver
  • Batteries
  • Access to local fuse or circuit breakers, if necessary
    • 1 Check to see if the Pro-Form device is properly plugged into a working, grounded power supply if none of the console buttons are working. Turn the device on and reset local fuses or circuit breakers if necessary; reset the circuit breaker switch on the base of the unit.
    • 2 Turn off the fitness device and unplug from the power supply if the console only shows zeros or the console buttons are not working. Use a standard screwdriver to open the battery compartment on the underside of the console. Pull out the old batteries and recycle, if possible. Replace with new batteries, using the old batteries as a guide for the size and type of batteries needed. Place the flat end of each battery against the spring inside the battery compartment and gently push the battery into place. Close the battery compartment and restore power.
    • 3 Press and hold the "Stop" button if the console is only flashing repeatedly, indicating that the device is in demo mode. Insert the console key and push the "Speed Down" button to turn off the demo mode on the unit. Remove the console key.
    • 4 Reset the console buttons if the incline is not working properly on the machine. Insert the console key and press one of the "Incline" buttons. While the incline is in the process of changing, remove the console key. Wait two or three seconds and re-insert the console key.
    • 5 Remove the console key and unplug the Pro-Form device if none of the above steps are resolving the problem with the console keys. Unscrew the three screws that hold the motor hood on the front of the device and pivot the hood off the machine. Find the magnet and small reed switch on the left side of the pulley. Turn the pulley until the magnet is aligned with the reed switch and the gap between the two is approximately 1/8 inch. Reattach the hood, screw into place and turn the treadmill back on
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 16, 2011 | Proform XP Weight Loss 620 Treadmill
F1 keep coming up have to power off a few time to get to work
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
This morning, all the buttons on the phone have stopped working except for 7, 8, 9. It was fine last night, and only this morning, I couldn't turn off the alarm on it and none of the other buttons are...
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Apr 14, 2010 | Nokia 6234 Cellular Phone
Error code f1/f2 --washer turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*$%^
Mar 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
2000 Celica GT - I can get into the programming mode just fine, but I have tried to program THREE separate remotes and none of them will program. They are used, so I am "rewriting" them, but they never...
I saw this on one of the toyota forums;
1) Getting a Replacement Remote
Look on ebay or google, make sure the remote has the following FCC-ID: bab237131-056
2) Installing the remote (credit to iPal)
1 open door, take key out...
2 insert and remove key from ignition 2 times
3 close and open driver's door 2 times
4 insert and remove key from ignition
5 close and open driver's door 2 times
6 insert key into ignition
7 close door
8 turn ignition from 'lock' to 'on' and back to 'lock'
if you do step #8
*1 time it's for add mode
*2 times for rewrite mode
*3 times for confirmation mode
*4 times for prohibition mode
9 remove key
10 then door lock will cycle 'lock' and 'unlock' a number of times
corresponding to your key cycles in step #8
11 press lock and unlock button together for 1 ~ 1.5 sec then release
12 then within 3 sec press lock button for 1 sec then release
13 if you did correctly door lock will cycle once...
if wrong, twice... then do it over...
Jan 27, 2010 | 2002 Toyota Celica
Have a Sentry V260 safe. The #1 button will not register when pressed. All other buttons register except for the #1. And the #1 button is in the combo. How else can I open it or how can I fix this button?
You can do a Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Dec 25, 2008 | Sentry Fireproof Safe
The number 1 button will not press
Key override
battery holder.
5. Open the door.
Dec 24, 2008 | Sentry Fireproof Safe
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
Proform Crosswalk 500 Treadmill Logo
5,048 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
