Check out this link: you have to scroll to the bottom of the screen to find the 'Next Page' to click on and progress through the manual http://mygshock.com/casio-manual/3054/
The correct time zone setting for Arizona on this watch is YEA (Edmonton International Airport). Hold the adjust button for several seconds until the three code time zone starts flashing, then use the forward/back buttons to select YEA.You need to keep the DST mode off, so press mode once, then the forward button to select off in the DST select screen. From there, you can then press mode to manually adjust each time/date area individually. The final thing that you can adjust is the language, choose ENG for english. Press adjust to keep your settings, and you should be good to go.
Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
To change time zone:Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then...To change to 12H mode:Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
It's depends on where you are. For instance, where there is no time signal radio station, your (radio-controlled) watch can't turn itself (adjusted to atomic time).
Take it back, the battery must have been changed sometime when it was in the store, and the back has not been sealed correctly. If the store won't take it back I would send to the company. If you don't want to do that, take it to a reputable watchmaker ( NOT A JWEWLER) and have them check out the seal, and how well the back was put on. If you have anymore questions, please feel free to ask. Good Luck!!
I have the same watch and thought I had the same problem. Casio's website actually DOES have the downloadable manual for this watch in their Support section, though it's kind of burried in their "Watch Manual Archives" section. Try to copy this address into your browser: http://world.casio.com/wat/download/en/manual/ FYI, the manual number you'll need to search for is shown in a rectangle on the back of the watch. In my case it was # 3054. When I downloaded the manual and read it, I learned how to confirm auto-updating is activated, and how to do manual updating. In my case, I was trying it from too far inside my house with a weak signal. When I set all of the settings as described and placed the watch in the window with 12:00 pointing outside as shown in their diagrams, the manual update feature worked like a champ. I also learned about a couple of other neat features hidden in the watch. Too bad the manual didn't come with the watch when I bought it; it would have saved me lots of frustration. Hope this helps you!
