Question about Norcent Technologies LT-2725 27 in. LCD Television
I need part number for this IC
I see where this ic has popped, but can't see the number.
My seiki tv keeps returning to the channel search screen, says search complete, I hit ok, for a second I have a picture then it pops back to the channel search complete screen.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Dec 01, 2016 | Seiki Televison & Video
What IC's uses the control of the focus motors
I'm assuming you will change these ICs yourself and that's why you're asking. If you have access to the circuit board, then you should be able to find some numbers on the IC which you think is blown. If you can pull that IC and look at it's underside you may be able to find a number you can search on the internet for. Or you can find a number on the circuit board itself and maybe find the company that made that board and contact them to find out the IC you need. You can probably find an IC match as long as the pins are in the same order and the voltages are the same. Good luck!
Oct 14, 2014 | Meade Optics
I have a Sony STR-V444ES receiver that is receiving what I believe to be a static discharge. When I turn on all components, I will receive a random loud popping sound that usually happens in the first 15...
The AVR have problem in its pre amplifier stage. Normally this type of cracking noise will hear because of faulty op amp (operational amplifier) ics. To repair such problems you should have through knowledge in electronics. And also need SMD rework stations Beacuse all the op amp ics are SMDs. If yo have such knowledge then i have added here the link to the service manula for your AVR.
Refer the page number page number 13 first. Its the Audio section blaock diagram of the AVR. you can see the the suspected ic in the top right corner marked as IC410. Which is the pre stage op amp for the frond left righ amplifier. You have to replace this ic( integrated circuit).
You can find the position of the ic by refering Page number 27. Its the input board . On the board you can see three ics with 8 legs(four in each side) On the left side. You have to replace the ic marke as IC410. You can find the schematic for the input board in page number 26. the The part number of the ic M5218AFP-T .
Refer the sevice manual to know how to carefully to remove the input baord.
http://sportsbil.com/sony/STR/STR-V/STR-V333ES_V444ES_V555ES_v1.2.pdf
If you need any more assistance feel free to conatct me through fixya.
Ajin
Feb 08, 2012 | Audio Players & Recorders
I need memory ic code for SONY TRINITRON KV-PG21P40
Hello
There is no code for memory IC. It is an 8 terminal IC, in which will have a number printed on it; usually laser printed. Check that number and buy the exact same number. That number is most important. OK.
Jun 19, 2011 | Sony Televison & Video
Turned on the tv this morning and heard a pop, now we got sound but no picture.it's a mitsubishi vs-50803 model
A real comman problem with that set is vertical IC will blow, burn a hold in the board itself, Part Number is a LA7838 Vertical IC, located right center mounted on a heat sink, and will about seven legs on the IC,, on defection board.Remove back and see if that IC is in pieces?
Oct 14, 2010 | Televison & Video
I need the IC # of JVC model KS-RT707
YOU DID NOT SPECIFY EXACTLY WHICH IC YOU ARE LOOKING FOR, BUT MORE THAN LIKELY YOU ARE REFERRING TO THE SPEAKER OUTPUT IC. THIS PART NUMBER WOULD BE AN HA13152. IF YOU ARE REFERRING TO ANOTHER IC, PLEASE BE SPECIFIC, INCLUDING THE LOCATION NUMBER......V
Jan 06, 2010 | JVC Car Audio & Video
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
WANT 2 KNOW 43FDX20B HITACHI TV IC NUMBER NAD PART NO
You can find OEM IC's for this model (43FDX20B) from a major Hitachi parts distributor on the link below:
Hitachi 43FDX20B Replacement Part IC
If you contact them and provide the generic number or location number of the IC, they should be able to provided you with the needed parts.
Apr 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Norcent Technologies LT-2725 27 in. LCD Television Logo
101 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
