Question about Refrigerators
Ice cube aker stopped working
Freezer on top, over 12 years old and in excellent condition
  • 883 Answers
The ice maker is operated by a small motor. look for it, disconnect the power and measure the voltage with a voltmeter from that connector source. If power is there, then the motor may have expired.
Posted on Nov 20, 2007
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
Dec 15, 2009 | Kitchen Ranges
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Ice make stopped working and now makes only 12 cubes per 12 hours
All ice maker operations are based on freezer temperatures. Check the freezer temps. If, you are satisfied your freezer is at zero or better. Then you need a new ice maker.
Jun 17, 2009 | Refrigerators
Fridgidaire side by side Ice cube jam
You can adjust the size of the ice cubes . if the cudes are too small or to big . they can get jammed... the timing screw is under the head cover clockwise is smaller . turn it one turn at a time... hope it helps
Jul 15, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Nov 13, 2007 | Refrigerators
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Sep 06, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
