During computer shut down, I get a message that clayoutengine-tooltip is having a problem shutting down. I don't like getting that sort of message during shut down as it indicates a problem which may be associated with viruses or spyware.
  • 52 Answers
That is an install error with Yahoo Messanger. If you do have yahoo messanger I would remove it and re-install it. And if already removed then make sure that the directory aka FOLDER is not there anymore. If it was me I would use Windows Live Messanger because its safe and plus u can still talk to yahoo friends.
Posted on Jul 20, 2009
    President:
  • 2,185 Answers
You should remove clayoutengine from the list of startup files.
Open Run and type msconfig.
Click Startup tab and uncheck the box corresponding to clayoutengine.
Monitor shuts itself down, "no signal" message.
nope. the resolution has bumped up for some reason out of range for the monitor. Does it only happen in the game? that might be a clue.
Feb 17, 2014 | Envision 19" Lcd Monitor H1981
Whistle in computer
Bogus unit - return it for another.
Aug 21, 2017 | E-Machines eMachines Desktop PC
Blue screen
Yes normally if you don't shut down your system properly you get this message, Solution : Log on to save mode and backdate your computer to the day before you got this message. If it doesn't work, you are gonna need to reinstall your O.S.
Feb 07, 2012 | Dell Inspiron 710m Notebook
HI I have a D865 PERL m/b. The CPU overheated, due to a load of dust blocking the heatsink fins. I have cleaned it all up and the heatsink should be fine now, but when I try and boot I get a message...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 14, 2011 | Intel D865PERL Motherboard
I have an Acer aspire 7738G laptop that shuts down from heat
try updating your video drivers, or reverting back to older drivers.
May 23, 2010 | Computers & Internet
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
My new lenova thinkpad t400 seems to be caught in a loop. I've taken the battery out and ctrl alt delete but still goes back to configuring updates: stage 3 of 3 screen and then says shutting down, but it...
Hello!
This is a tough one. I've seen this recently and had to just press and hold the power button to shut down. Not good!
I'm assuming you're using Windows of some sort since it shows "Stage 3 of 3" when it does updates during shut down.
What has happened is you downloaded some sort of "fix" from Microsoft and it's getting stuck while trying to install. I've had this happen and have never found a good solution for it.
1. Turn you computer off.
2. Turn your computer on
3. As soon as the power comes on, start pressing F8 repeatedly.
4. When you get a black and white menu, use your arrow keys to move up and down, select "Last Known Good Configuration" and press enter.
What the solution I've provided does is revert your computers software to a point in the past, hopefully just before you received the screwy update.
Make sure to rate the solutions you get!
Aug 08, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Acer 5100
Are you able to restore the computer if so that may be your problem. By the way you have explained it seems like a software problem and not a hardware one.
Nov 19, 2007 | Acer Aspire 5100 Notebook
Computer will not shut down
You can try the Ctl-Alt Del keys to see if you can get the task manager to come up. If you can then try to shut down using that. If not then the only choice you really have is to manually power down and restart. Chances are pretty good Windows will clean up after itself and should boot backup. During the process if you receive any error messages or warnings document them. Windows may also prompt you for a hard drive scan, let it. Let us know what happens and please don?t forget to rate this post.
Apr 16, 2007 | Compaq Armada E500 Notebook
Computers & Internet Logo
1,884 people viewed this question
David Payne
David Payne
