Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
Error F5 on a kenmore electric range Model 911-469-8812
The error message occurs when first tring to bake.You hear some clicking normally and then the fault.The stove will work sometimes.
It has a manual door latch/lock and after I read some other comments I moved it to lock and then back. The oven did start up normally.Thanks
  • 3 more comments
  • hammerman Nov 29, 2007
    Thanks Chris72 The EOC did correct the problem.Funny I have all the original documentation on the stove and no mention of Error Codes...Jeff
  • DonnaDyer Oct 11, 2008
    I have the same error code F5 00 or 01 with the model 790.9912.
  • Anonymous Jan 26, 2009
    I have a kenmore electric stove and the oven does not turn on or sometimes it turns on and turns off after a while and displays an F3 code. The glass top burners work fine. Can you help me figure out the problem. Thank you.
  • Anonymous Mar 27, 2014
    MY ELECTRIC RANGE WILL DISPLAY F7 AFTER REACHING 400 PLUS DEGREES AND THEN WILL SOMETIMES LOCK THE OVEN DOOR
    MY ELECTRIC RANGE WILL DISPLAY THE F7 ERROR AND SOMETIMES LOCK THE DOOR WHEN THE TEMPERATURE IS 400 DEGREES OR HIGHER
  • 213 Answers
F-5 stands for faulty oven control called the EOC youll have to replace the control to fix problem
Posted on Nov 21, 2007
Oven does not heat up, and is on celsius
Posted on Nov 01, 2009
Whirlpool gold accubake system keeps displaying the message "Dr Lo". Every 60 seconds it will beep like 10 times and display the message then display "start?" Normal function dont work either I can push...
The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
Dec 18, 2013 | Kitchen Ranges
Maytag stove model JJW9530AAW not working
https://removeandreplace.com/2017/03/21/maytag-oven-error-codes-stove-range-fault-codes-causes-and-solutions/
Nov 20, 2017 | Stoves Ovens
E1 F5 error message on my kenmore range
This is a door lock error
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct. What is the model number?
Dec 07, 2012 | Kitchen Ranges
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
Kenmore oven code f5 can't get door to open
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore 9535 Electric Range
I self-clean my oven last night. It still says it is looked and I see E1-F5. I can not open it. I even unplugged it but it went right back to the same message.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^$R
Aug 19, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
We used the self cleaning option on our Kenmore Gas Range (model number 665.72004101 or 665.75004101) and now the oven door remains locked and the error message on the screen is e1 - f5. How do we unlock...
Dec 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Getting F13 err code when trying to bake or broil. Frigidare model PLES399EC
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Oct 22, 2009 | Frigidaire PLES399EC Electric Kitchen...
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
1,097 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
