Question about Frymaster Dean H14 Deep Fryer
HOW TO SEPARATE PUMP FROM MOTOR - Frymaster Dean H14 Deep Fryer
    Scholar:
  • 81 Answers
There are 4 bolts on the back of the Haight pump on both the 5 or the 8 gpm model. Remove these 4 bolts and using a dead blow hammer, give the pump a sharp blow to the top then the bottom & this should seperate the two. 90% of problems with these pump & motor assy's are from poor oil filtering practices, not having the crumb catcher in place & crumbs getting past the paper & into the pump. The tolerences between the two cams are very tight & believe it or not, a pencil eraser size bunch of crumbs can jam this pump. I go on 3 calls average a month on Dean fryer pumps and after they sit there and run/hum and trip the pump breaker, you WILL burn the motor up. I have a perfectly good used assy from a Dean fryer if needed.
captrick
capt_rick1912@yahoo.com
Posted on Jul 29, 2009
How to replace impeller
take bolts out to separate wet end of pump and motor then remove screw if one on impeller sometimes they are backwards threads take screw out then unscrew impeller while holding shaft of motor that should be a regular thread separate backing plate from motor change seals then revese
Jul 06, 2014 | Pool & Spa
How to separate pump from motor
take screws off around housing that separates motor from wet end remove diffuser then remove screw from impeller backwards thread and hold back shaft of motor after removing still hold shaft and turn impeller off regular threads make sure to replace seals
Apr 16, 2013 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Where is the fuse for the front windshield washer motor
If you are just talking about the windshield washer pump/motor that squirts water on the front windshield, there is no separate fuse for that pump. If you are talking about the front windshield wipers themselves then the fuse for that (including the washer pump) is located is the fuse panel inside the vehicle down below and to the left of the steering wheel. Below is a diagram of the fuse layout (first picture) and I marked the 10 amp fuse for the system. As I said if you are talking about the pump/squirter motor there is no separate fuse. Inside the wiper motor itself (located basically on the firewall on the drivers side) is an internal microprocessor as well as an internal relay for that pump. If the processor or the relay is bad, both are internal and the whole wiper motor assy. has to be replaced. It's one complete unit. There is a chance that the pump motor itself could be bad. In the second picture is a breakdown of the washer fluid reservoir. In order to get access at it which is where the washer pump motors are located the right front wheel and splash guard have to be removed. I have marked the 2 washer pump motors which are mounted on the reservoir. I cannot tell you which motor is which but the one for the front has 2 wires at the connector (a black & white wire and a black wire) The rear pump motor has a violet & light green wire and a black wire at its connector. That's how you can tell which one is which. You can test the motor by either pulling it out and applying direct power and ground to it to see if it engauges or while someone is engauging the washer inside the vehicle while you are down there, see if you are geting power at the black and white wire. Check that wire while it is disconnected and using a good separate ground. If you are getting power make sure the black wire is geting a good ground. If all is good (ground & power) than more than likely the pump motor is bad. If you have a power supply problem at the black & white wire than you are looking at most likely a bad wiper motor assy but check for an open power wire from the wiper motor to the pump motor. It's not quite as simple as it used to be. The wiper motor on your vehicle has like a mini computer in it. I'm gonna say the washer pump motor is bad which is the most common. Hope I was able to help and that I didn't get too technical on you but things are not like the old days with separate motors (wiper and washer).
May 19, 2012 | 2004 Mercury Montery
I have a flotec pump model FP4122-08, motor #C48J2EC11C3, and a recent freeze broke the motor flange where it bolts onto the pump body. I need to replace the motor base flange but My parts list does not...
I believe the part you actually want is the motor endbell that houses the front motor bearing and it in turn allows the motor to be connected to the pump housing. The number you give is the motor model number...I will also need the motor serial number to ensure we quote you the correct version of the endbell you need as there are design changes from time-to-time. Please email than information to me via the contact us part of our website at www.arrowmotor.net. You should be able to purchase the endbell assuming AOSmith still makes it.
John
Jan 03, 2011 | Garden
Removing pool pump impellor from motor shaft
Separate pump and motor. Remove diffuser. Remove back cover from motor. Motor shaft has either a slot for a screwdriver or a flat area for a wrench. Hold shaft and unscrew impeller.
Feb 24, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
I would like to replace the seal between pump and motor on model# pf-30-2n2c waterway spa pump how do you separate them
Pull the pump's front cover, lock the opposite end of the motor shaft, unthread the impeller, loosen the 4 motor thru-bolts then you can pull the seal plate.
Oct 26, 2009 | Pool & Spa
Hayward 2607 pump
FROM WHAT I CAN SEE ON MY SCAMATIC THE PUMP HAS A MECHANICAL SEAL, THE PUMP IS FROZEN TO THE MOTOR YOU CAN GET THIS APART BY TAPPING WITH A PLASTIC MALLET AND PATIENTS THEY CAN BE TOUGH SOME TIMES
Aug 22, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Frymaster Dean H14 Deep Fryer Logo
204 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
