Question about Microwave Ovens
Hi This is a follow up from an earlier report with additional info. I have a kenmore elite electric range. The control display is showing an error F13. The oven does not work and we have unplugged the stove for 30 min and turned it back on with the same error result. Please help. Thamks Richard
  • 2 more comments
  • rmussak Jul 20, 2009
    Model No. C970-688022 - Canadian
    Ok...signing off for tonight.....will follow up tomorrow
    I already did as suggested. So I need to replace the EOC. Specifically where is this device and what do I need to do to replace it? Can you supply the part number?
    Thanks
    Richard
  • rmussak Jul 22, 2009
    Hi
    Could you please provide details for the installation of the EOC?
    Thanks
    Richard
  • 1,272 Answers
The F13 indicates a problem with the EOC (Electronic Oven Control board). This can be caused by a power surge or glitch through the electrical supply lines. You can try disconnecting electrical power completely from the range by unplugging it. Leave it unplugged for a few minutes. If the fault code returns when you plug the range back in, then the EOC will need to be replaced.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 20, 2009
  • 2 more comments
  • Anand Gupta
    Anand Gupta Jul 21, 2009
    Yes. I do have the part number. However it wil take couple of hours before I supply that information to u. Pls wait for my comments.
  • Anand Gupta
    Hi, Thankx for waiting. The part number for the EOC is AP3770108
    Get it replaced by a service technician. It is quite complex.
    Regards
    Anand
  • Anand Gupta
    Anand Gupta Jul 22, 2009
    You need to open the cabinet and then just swap the cables of the faulty EOC with the new EOC.
    Regards
    Anand
  • Anand Gupta
    Anand Gupta Jul 27, 2009
    Has the issue resolved? If not, then please let me know so that we can work for a solution!
    Regards
    Anand
    President:
  • Microwave Ovens Master
  • 1,714 Answers
Can you give me the model number?
  • Craig Butler
    Craig Butler Jul 20, 2009
    The first part of the model (C970) tells me it's a Kelvinator (made for Kenmore) range. I can not find a F13 code in the Kelvinator fault codes. I'm not sure what to do here. I will have to get back to you...
How to turn the oven light off on my Kenmore Elite Electric stove model790.
You should have either a shorted out door switch or a shorted out light switch on the control panel.
Removing either one and unplugging it should show you which one is the problem.
God bless your efforts.
Nov 30, 2016 | Kenmore Microwave Ovens
I have a kenmore elite range model number 790 46809 991 and the burner on both the left and right are acting up. They both show that a burner is on on the control panel (not surface indicator) and the...
Hello gralexander,
The problem you are experencing is with you control switches. The cheapest place i can find the switch is from searsparts direct. Here is a link to the webpage http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046809991/0583/0124160/P0050380/00001?blt=06&prst=0&shdMod=79046809991
You will see a diagram in the top left side of the page use it to locate the switches that are bad and order them from sears. You may also need the burners to check them you need a continutity tester.
1. Remove the burner from the socket
2. Take your test and touch one probe to each side of the burner.
3. If you have continunity then the burners are good
4. If not you will have to order burners as well.
Changing the switches:
1. Unplug the range
2. Remove the back panel where the switches are.
3. Remove the knob from the front
4. Remove the screws from the switch you are replacing (Due one at a time)
5. Move the wires from the switch to the corresponding terminal on the new switch
6. Replace the switch and screw in place
7. Do the other switch
8. Reinstall the cover on the back of the unit
9. Plug in and try
Doing all of the above steps should fix the problem that you are having. Please make sure that you install L1 to L1 and L2 to L2 on the new switch other wise you will cross wire it and the rest of the switches will short and need to be replaced.
Thank you for choosing FixYa.com. If you have any other questions please post back to this thread and I will do my best to help you with your Range problem
Justin
Mar 10, 2011 | Kenmore 63252 Microwave Oven
Lost my oven control guide. how do I set the self clean function on the kenmore elite dual fuel range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 04, 2011 | Microwave Ovens
My Kenmore Elite will not heat has F-9 on display
Hello :
F-9 error code indicates a defective control board, inverter module or line voltage too high You can try unplugging or disconnecting the electrical power to the unit for at least 50 seconds to see if this solves the problem, if not then I recommend to replace the inverter module, if this does not solve the problem then the control board will have to be replaced. If that didn't solve the problem , then call for repair .
I hope this will help .
Please rate !
Mar 27, 2010 | Kenmore 64683 Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Where is the capacitor located in the Kenmore Elite?
It depends on the model. It's usually behind the grille or control panel.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 01, 2008 | Kenmore 62622 Microwave Oven
Sears elite keypad not functioning
Sounds like you have a defective control panel.
We repair these for customers nationwide with our guaranteed $39.95 service.
In some cases, it may need parts, but we would contact you first for your approval for any additional charges.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 01, 2008 | Kenmore 63672 Convection/Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
