Question about Frymaster Dean Kitchen Appliances - Others
I have a FPRE217SE and the control panel comes on and later it reads hot and the oil starts smoking. Is this a thermostat issue and where can I get the technical manual for this machine? cbbuckeye
  • 601 Answers
Hi....
It is problem with the thermostat, you can get the Service Documentation from the link below.
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
Thanks
Smith
Posted on Jul 20, 2009
2002 dodge caravan sport overheated. It has a new radiator and hoses; we changed the thermostat and replaced the relay and pigtail for the cooling fans after it overheated but we still have the overheating...
Double check the thermostat and make sure the water pump is doing its job. To check the thermostat, simply take it out and reassemble the housing with out the unit. Run the engine and hopefully it will get warm to hot. If not check the pump.
Oct 16, 2013 | 1997 Dodge Grand Caravan
1996 jeep Cherokee country 130k miles recently had oil filter changed and broke the oil sensor gauge...had them replace gauge sensor causing the new filter to be reinstalled. Several weeks later after two...
There is either A).an oil leak or B). the smoke is from residue oil spilled on exhaust and such during the repair. Crank the engine and look everywhere for an evident oil leak if one is not found leave it run till it gets hot enough to show where the white smoke is coming from and see then if it is residue or a new leak. Remember to rate my answer and leave testimony this is how we earn our milestones here of FixYa remember we are all volunteers here so answers may not come as fast as you like please be patient thanks in advance.
Sep 30, 2013 | Jeep Cherokee Cars & Trucks
2003 lincoln aviator/how do you know if there's motor damage
Your car shouldn't have just suddenly started burning oil. Its possible it's leaking in the engine compartment and the leak is dripping onto the hot exhaust manifold and the. The smoke is blowing out the back as you drive. I would think it's unlikely that the engine has been damaged since the check-engine light should have come on if the oil level was low enough to cause damage.
If hii find that bluish smoke is coming from the exhaust pipes, then the next thing to check is whether it smokes on acceleration or deceleration. If the latter, it may be just a valve issue. If it smokes a lot on startup, then it may be rings.
Aug 09, 2017 | 2003 Lincoln Aviator
Ok...this car is really taking me for a trip...a few weeks after I bought it..I thought the light on the dash was tire pressure but the mechanic said it was a warning light for the lights (which were...
You have too many unrelated problems for this to be a simple fix. I HIGHLY Recommend you go to Car Fax and see if this car was a recovery from a flooded area because that is the only thing that makes sense of all these problems. If it was then you should contact you local DA about the issues with the car and the fact that it was not identified to you that the vehicle was recovered from a flooded area and had water damage. This is required under the law and the dealer or person who failed to tell you this is obligated to give your money back or fix the vehicle at no cost to you. The only time I have seen these types of faults all at once is in a faulty ECM that has faulted due to water damage.
Aug 11, 2011 | 2002 Lincoln LS
1st issue. My car has suddenly started smoking, white smoke from the exhaust, did I overfill the oil or is it more sinister than that. I haven't lost power that i can notice. Will excess oil burn off like...
You might be looking at a head, or head gasket issue. White smoke is usually due to coolant mixing in your combustion chamber, or cylinder. Blue smoke is from oil. Your loss of coolant and high temperature might be the clue. A leak down test and coolant system pressure test should tell the tale for you.
Sep 01, 2010 | 1996 Hyundai Accent
Honeywell T86F thermostat (controlling oil-fired hot water baseboard heat system) comes on on demand but will not cycle back on after zone cools - or it just takes too long???
T-Stat started smoking when activated last night. I swapped it out with one from another zone and have ordered a replacement. - www
Nov 24, 2009 | Honeywell Heating & Cooling
Rmy car is running hot, change oil light is on, low coolant light is on, and i have no heat
do u have white smoke coming out of tailpipe and check oil if it is overfull and looks like chocolate milk most possible a blown head gasket--if you dont have those problems than check coolant holding tank for proper level run vehicle and let warm up if thermostat doesnt open or water pump not working heater core lines will be cool and vehicle will start to over heat but have engine trouble codes read sum auto stores such as auto zone /advanced auto do it for free
Oct 19, 2009 | 2002 Chevrolet Impala
My 300zx got smoke issue but im not sure.smoke come both sides when i start the car.it got little oil leak from turbos.but once engine got hot the smoke goes away.when driving it doesnt smoke.but it...
It sounds like you may need valve seals.
The oil sits in the head after the engine is cut off and leaks around the seals into the cylinder.
When you start the engine it burns the oil and sends the smoke out of the tailpipes.
It does not hurt anything much if it is not to bad.
Jun 04, 2009 | 1990 Nissan 300ZX
My truck blows white smoke
Hello!
There are two differnt reasons for black and white smoke coming from the tail pipe.
Black smoke means fuel runs rich (car getting to much gas). Check fuel pressure/air filter.
In some cases the white smoke means car is burning oil or transmittion fluid. Have tem checked/replaced.
If you can feel a smelly smoke it can be catalytic converter.
In a worsest scenario if car blowing white smoke it can be engine coolant is getting into an engine cylinder from a bad head gasket ,or a warped/cracked head. So you need to keep your eye on coolant level and check your engine for overheat. Also might be good to check your oil for traces of coolant (on a dipstick it would be a milky substance mixture of oil and coolant).
Good Luck
Dec 06, 2008 | 2006 Ford F-250 Super Duty
Open Questions:
Kitchen Appliances - Others Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
