Watches Logo
A
Annita J Holt Posted on Nov 17, 2016
How to reset time on nixon minimize 42-20 watch
4 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 21, 2008
SOURCE: how to set time on nixon scout watch?
Visit: www.nixonnow.com/manuals/nixon_analog.pdf
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 10, 2009
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Anonymous
  • 183 Answers
  • Posted on Sep 18, 2009
SOURCE: With
Pull out the crown to the first or second set position then press and hold down the start button. The sweep arm should begin to move into the right position. Once it is at 12:00 or 0 release the button and press the crown back in.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 03, 2017
SOURCE: Where is the serial number on a nixon minimal the time teller 100 m stainless steel japan movement 16g.
It would have been on the box it came in.
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Full Reset
I have a PDF for the entire manual. http://www.nixon.com/manuals/nixon_5130_4220.pdf Have fun. And take your time. The instructions are a bit specific.
1helpful
2answers
It says rom fail on my lodown 2 and i was wondering if anyone knew how to reset the watch?
Here some tips to deal with a Nixon Lodown:
1) Sleeping mood (display is off, all buttons lead to the same reaction: display shows time for some secs and then turns off again. This mode is for battery energy saving, switch it on and off by holding (c.a. 2 secs) the light button.
2) ROM FAIL: it happens that the lodown shows ROM FAIL and constantly restarts. It happened on my watch while I tried to change time zones. Here is what to do about it: Bring it to a professional watch repair store and get the battery replaced. The watch restarts automatically and works perfectly fine again. DON'T send it to Nixon, they will charge you for shipping, battery replacement, the new battery etc. Although it should be covered by the guarantee. Just get a new battery, it cost me 16 USD and the watch is good again, waterproof and works perfectly. Nixon authorized repair centers will charge you extra for pressure testing. I had this on my second Lodown, after I had it two weeks only...
3) Watch freezes: All digits are on at the same time, none of the buttons brings a reaction. I had this problem on my first lodown. Just get a new battery, that solves the problem. But again DON'T use authorized Nixon repair centers, it costed me almost 45 USD, just to get a new battery. Although the watch was only 1 year old and guarantee should have covered this case.
In general the Nixon Lodown is a good watch, looks good, has all features you need, as long as it works. The problem with the watch is, the above problems occur pretty often. I have my second Lodown now and I am very disappointed with the Nixon customer service. Although clearly guarantee cases, they will charge you for every single problem you have with the watch. My advice, bring the watch to a regular watchmaker.
After all, I don't understand why the Nixon Lodown manual does not mention all the above issues. The manual is completely useless, very poor from Nixon. You have to dig online to solve any issues on the watch. In summary: The Nixon Lodown watch is good, Nixon customer service and guarantee is a joke. ROM FAIL and freeze is solved with replacing the battery.
4helpful
2answers
How to i turn off the hourly beep on my nixon lowdown watch
This is not done in the alarm section. In the time view, press and hold the wave#/reset button (lower right) until it beeps (3 seconds). That's it. The watch should be silent now when cycling through and on the hour.
Sep 06, 2010 • Watches
5helpful
Nixon super rover..need to know how to reset the chronograph
Pull the stem all the way out...like your setting the date. Then hit the upper button and that will move the hand 1 second at a time until it gets here you want.
Top Nixon Watches Experts
ZJ Limited
ZJ Limited
john h
Are you a Nixon Watch Expert? Answer questions, earn points and help others
