Question about GE (PSS26MSRSS) Side by Side Refrigerator
Popping noise off and on
Sound more in side . hard to tell
    President:
  • GE Master
  • 1,922 Answers
If alls working as usual i.e. its staying cold both ref and freezer its probably just the self defrost doing its job
Posted on Jul 28, 2009
Eliminate variable popping noise, sometimes once, sometimes 6-7 times quickly, sounds like a popgun a young kid might have had in the 50's 60's
Thank you for your inquiry, friend!
Based off the information you have provided the popping noise could be the damper. It is known to make popping noise this would be a normal operation for your appliance. I hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
Loud popping noise
when you changed the hub assembly did it come with a new wheel bearing? jack the vehicle up and move the tire up and down and then side to side and check and hear for play on parts if there is play in something then that is your problem to me it sounds like your inner tie rods does it pop on both ends ?
May 07, 2014 | Ford Explorer Cars & Trucks
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
Ford courier front end knock- clunck
About all the advice I can offer on noise concern is to have a trained technician road test the truck with you and listen to the noise. Noises are hard to diagnose in any type of setting much less over this computer keyboard
Jul 27, 2012 | Ford Ranger Cars & Trucks
The freezer side of this unit quit freezing. Everything is thouging out. Fridge side isn't as cold as it used to be. Both controls have been set on factory recomemded settings since install. I keep...
A popping noise? Could it be the clicking of a relay? There is a relay that activates the compressor that could cause a clicking sound if it doesn't hold. A popping sound could be a bad capacitor but normally isn't a continuous popping sound, unually only one pop.
If the unit is only 4 monthes old it should still be under warranty and you should call it in for repair.
Jun 16, 2011 | Refrigerators
Clicking noise down by the front tires.
check your axles, for an open cv boot, this clicking is on straigth or turning, if turming to your rigth you hear noise to be louder on your left then your left axle is bad, do the same to your left and if noise exists then your rigth axle is bad.good luck
Feb 27, 2011 | 2003 Dodge Caravan
My 2001 drivers side window cable broke for the power window are the cable hard to replace
drivers window works with help, it pops and grits like glass rubbing steel. Took glass lose from carrier glass works free, but the cables make noise and move very slow befor kicking braker.
Mar 01, 2010 | 2001 GMC Sierra Crew Cab
98 honda accord makes a popping noise on front driver side
check your disc pad they maybe worn out already. then check the disc plate also.
May 10, 2009 | 1998 Honda Accord
GE (PSS26MSRSS) Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
