I cannot print my register from Quicken - Computers & Internet
  • 9 more comments
  • sppeterso317 Jul 20, 2009
    I GET NO ERROR IT SAYS ITS PRINTING BUT HAS ZERO DOCUMENTS TO PRINT
    I CAN PRINT EVERYTHING ELSE JUST FINE
    I'VE DONE THAT AND IT STILL DOES NOT WORK
    IT SAYS ITS GOING TO THE PRINTER CORRECTLY
    PRINTER SETOP IN QUICKEN SAYS C3100ON NEO1 DON'T KNOW WHAT NEO1 MEANS
    P PHOTOSMART 3100 SERIES
    I CAN'T FIND THE DROP DOWN LIST
    YES I DID
    IT SAYS I CAN'T I NEED TO GO TO MY WINDOWS PANEL
    YES AND IT ONLY GIVES ME THE c3100 SERIES ON neo1
    I'm quitting for the night..nothing worked
    President:
  • 2,777 Answers
Does it tell you a specific error? Are you certain you are selecting the right printer when you are trying to print? Are you able to print other things just fine? Please let me know the error and we can figure this out.
THanks
Tim
Posted on Jul 20, 2009
  • 9 more comments
  • Tim Grayson
    Tim Grayson Jul 20, 2009
    Are you sure you have the correct printer selected? Go to file and print from there, it should ask you to verify the printer. It sounds like its trying to print to the built in document printer in windows, not your real printer. Also you can click start, go to printers and it will bring up a window with your printers. Right click on your actual printer and make sure it set to default.
    Thanks
    Tim
  • Tim Grayson
    I'm sure it's a print setup problem in quicken, try the file - print steps like I mentioned before and make sure the printer is default. Also, try a FILE - Print Preview in quicken, does it look normal there? Does it say its going to print to the correct printer?
    Thanks
    Tim
  • Tim Grayson
    Does the print preview look normal? You are probably checking that now. Make sure you back up your quicken in case you need to reinstall. Also, have you been able to print the register in the past? Could you please turn off your caps lock key, it makes it very difficult to read all capitalized letters.
    Thanks
    Tim
  • Tim Grayson
    Have you tried a simple reboot? If the preview looks correct and it shows the right printer, something is going on.
  • Tim Grayson
    Not exactly sure either, to me it would mean network 01, is the printer directly connected to the computer? What is the name of the printer under the printers window if you go to start, printers?
  • Tim Grayson
    Well that sounds like the problem right there, you should be able to select a printer in quicken that is identical in name to the one in the printers window in the control panel...
    Check the drop down list of printers.
    Tim
  • Tim Grayson
    When you go to FILE then PRINT in quicken it should let you choose your printer right there. Also, did you make sure that the correct printer is marked as default in the Printers window we keep going back to?
  • Tim Grayson
    Ok good, did you find where you can change printers in Quicken
  • Tim Grayson
    That doesnt make any sense, according to the quicken documents you should be able to go to:
    File menu and select Printer Setup for Reports/Graphs.
  • Tim Grayson
    What version of Windows are you running? Please turn off your CAPS LOCK key.
  • Tim Grayson
    Ok, have a good night
How do i change the print size on my register
Edit>Preferences>quicken preferences>register and then click on Fonts
May 06, 2016 | Royal Alpha 1000ML Cash Register
How do you change VAT rate on Quicken 2002
You cannot do this on the normal account register, as you might have done in earlier versions of Quicken. You have to use two special registers, by creating a BUSINESS BILLS and a CUSTOMER INVOICES register. To do this tap the CREATE NEW ACCOUNT button, in the MY FINANCES screen, and select these registers from the dialogue box. When you receive a payment from a customer, open the CUSTOMER INVOICES register. Then... 1. Tap the TYPE box, and choose INVOICE from the drop down list. This will enter INVC into the box. 2. Look at the button under the BALANCE column. Instead of the usual SPLIT button, this is now labelled FORM. Click on this, and a Customer Invoice Form will appear. Fill in the details from the invoice you have received. Under AMOUNT enter the amount received, less VAT. In the V column, enter the symbol for the appropriate VAT RATE, and Quicken will calculate and enter the VAT amount. 3. When you have completed all the required boxes on the form, click the SAVE AND DONE button, and The form will close. 4. You will see that Quicken has entered the details in the correct Registers. I 5. When you produce your VAT REPORT your item will appear with its details in the correct places. The process for entering a payment is similar, but you will then be using the Business Bills register. Problem solved ! John Cunliffe
Feb 13, 2011 | Intuit Quicken 2002 Home and Business Full...
Printing check error code 7224
Using Quicken Premier 2009 on Windows 7 x64 with HP OfficeJet 7310.
My check wouldn't print and was booted out of Quicken. Validated data (was OK), reinstalled Quicken Premier 2009 (per instructions above), checked printer and driver (was-OK), I still could not print checks (error code 7215 and quicken closed).
SOLUTION: I deleted the transaction I was trying to print, the re-entered it. It printed fine.
Feb 13, 2010 | Intuit Quicken Premier 2009 for PC
Quicken reports & reconciliations wont print
If your printer prints other documents properly then it is a problem with the driver for your Quicken program. Go to the Quicken site and upload the latest driver for your operating system.
http://support.intuit.ca/quicken/en-ca/index.jsp
Jan 19, 2010 | Intuit Quicken Starter Edition 2008:...
Have 2001 quicken running on windows vista. when i try to print the check register, it says cannot open printer. i bought 2009 quicken and started to install, but it said it cannot save old register. it...
Dear Sir/Madam,
To resolve this issue:
  1. From the Quicken File menu, choose Printer Setup, and then select the form that you are trying to print.
  2. Make sure that all selections and settings in the Printer Setup window are correct, especially the selection in the Printer drop-down list.
  3. If all information is correct, click Cancel and proceed to step 4. Otherwise, click OK after making the necessary corrections, and then try printing again.
  4. If the message persists, exit Quicken.
  5. Click the Microsoft® Windows® Start button, choose Settings, and then choose Printers.
  6. Right-click your printer and choose Properties.
  7. Click the Advanced tab, clear the Enable advanced printing features checkbox, and then click OK. Restart Quicken and try printing again.
  8. If the message persists, exit Quicken.
  9. Double-click Add Printer and proceed through the Add Printer wizard until you reach the window that asks for the printer manufacturer and model.
  10. Select the manufacturer for ex. HP, and then select the printer HP DeskJet 550C (or any other HP DeskJet 500 series printer). Follow the onscreen directions in the wizard to finish adding the printer.
  11. Restart Quicken. From the File menu, choose Printer Setup, and then select the form that you are trying to print.
  12. Select the printer you added in step 10 from the Printer drop-down list and then click OK.
Completely uninstall the old version and install the new version. Before install clear registry and temp files. Update the latest driver for printer.
Thanks
Good Luck
Sep 24, 2009 | Microsoft Computers & Internet
Quicken 2009 Deluxe will not print on Vista 64 system on HP 5610 All-in-one printer - ran all the usual suspects about drivers, rebooting, selecting right printer, etc. etc. no luck. Seems Quicken does...
Me too. None of my printers worked and each time I tried Quicken crashed. But only quicken had this problem. Then I read this super simple fix:
  • Click Edit from the menu bar, and choose Preferences > Quicken Program.
  • Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  • Click OK.
  • Print checks.
At this location: http://tinyurl.com/moehn3
Worked like a charm. Go figure. Wasn't even a duplicate check number.
Aug 18, 2009 | Computers & Internet
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
Go to print checks and application closes
I had the same problem and contacted Intuit. If there are any duplicate check numbers for the checks you are about to print, a bug in R6 causes the program to blow out. I had some check numbers that were from over 10 years ago that were causing the problem. Go in and tell it not to warn for duplicate numbers, and it may fix the problem. They said it is to be cured in future releases.
Jun 10, 2009 | Intuit Quicken Premier 2009 for PC
Basic Quicken on Windows Vista will not print to HP psc 2410
Symptoms:
This issue occurs after updating to Release (R6). Quicken is attempting to display a duplicate check number message, when the error occurs. We have identified this issue to be caused by one or more duplicate check numbers in the checking register.
Solution 1
  1. When clicking Print Checks, the next Check # to be printed is displayed. Take note of the check #, and then click Cancel.
  2. From the Checking register, click Find and search for the check number.
  3. Edit the transaction(s) to include the correct check number, or remove the check # from the transaction.
  4. Print checks.
Solution 2
  1. Click Edit from the menu bar, and choose Preferences > Quicken Program.
  2. Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  3. Click OK.
  4. Print checks.
May 01, 2009 | HP PSC 2410 All-In-One InkJet Printer
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
