Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
How to open the case of an external acomdata hard drive?
  • Bruce Kaufman
    Bruce Kaufman May 11, 2010
    why are you trying to remove it from the case? Did your drive fail? Unless you have a bench and possibly a cleanroom you are not going to be able to repair the drive...
    If you need a solution for data recovery I have an excellent resource...
Chinthakaj
  • 416 Answers
SOURCE: Can't open hard drive enclosure
A Details Guide too remove the Disk.
http://www.gearhack.com/myink/ViewPage.php?file=docs/AcomData%20E5%20HybridDrive%20External%20Hard%20Drive%20Disassembly
Posted on Feb 02, 2009
  • 78 Answers
SOURCE: "how do you open case ,ximeta ndu10 120 external hard drive"
On the plastic sides of the case, near the back, there are 2 holes - one on each side. Inside these holes are recessed plastic tabs. You should be able to look in the holes and see part of the tab.
They don't take much force, but if you insert a straightened paperclip or coat hanger, just enough to push the tabs a couple of millimeters, you can then slide the top half of the case forward and off.
Posted on Jun 09, 2009
Crankstart
  • 696 Answers
SOURCE: flashing red/blue acomdata 1 terrabyte external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: How to open case: Seagate ST3160203U2RK External Hard Drive ??
This is one of the mean tricks that the industry uses to discourage people from opening things and then totally ruining them.
What about getting yourself a 5-star-shaped screwdriver? Ask your hardware store guy.
Too expensive? Well - I have a lot of different simple slotted screwdrivers. Normally I find one that fits into 2 corners of these "miracle screws". If you don't have fitting one use a cheap one that is slightly too large to fit and grind it down just to size.
The same trick works with the other kind of "discouragement screws" that have ALMOST a normal slot --- but there's an elevation in the middle of it. A slot screwdriver with a ground-in **** in the middle (Dremel tools work fine) does the trick.
Posted on Sep 24, 2009
SOURCE: Forgot Acomdata External Hard Drive Password
Did you every get this resolved? I have same probelm.
Posted on Dec 24, 2009
Trouble with my Acomdata external hard drive and my mac
Unfortunately it seems that Acomdata is no more on businness.
In order to get support you can try writing an email to techsupport@acomdata.com
Feb 04, 2013 | Acomdata Computers & Internet
Acomdata backup hard drive
open your cpu chk all cable then try to on
Jul 19, 2008 | Acomdata Computers & Internet
I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
Hope this helps!
Regards,
Joe
Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata external HD not read. Clicking sound.
Try taking it out of the casing and putting it into another external hard drive case. That is if you can, if its making a clicking noise it probably means your hard drive went bad or it means its not getting enough power to run make sure all the cords are hooked up tight. I had that problem once the hard drive wasn't getting enough power and i had to mess with it on the inside to make it have enough power. I'm not saying take the hard drive apart im saying take the casing off it and check the inside cords to see if they are tight enough. If that doesn't work leave a message and ill try to help again.
Jan 04, 2010 | Acomdata HybridDrive E5 Hard Drive
I can't seem to open my external acomdata hard drives. My computer doesn't recognize them and when they do open they will close in a few minutes.
Either the power-supply for the external drive is dying,
or the disk-drive inside the external case is dying.
Quick, make a "backup" of all the files on your ACOMDATA, before it totally "dies".
If it still is under warranty, exercise the warranty, and replace it.
Nov 13, 2009 | Iomega HDD External Desktop (32660) 80 GB...
I need to replace the dura micro dm5133u ac adaptor for my acomdata external hard drive.
Now, if you can't find an external hard drive adapter for your drive, can I ask you is it for a laptop or desktop.
If it is for a desktop, you can actually open the drive casing and take out the internal hard drive and plug it into your computer.
Sep 30, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Installing old drive into new drive
If the problem is in the controller inside the case which in 99 percent of the times it is, This will certainly fix your problem. The MTBF(mean time between failure) of harddrives is 100,000 hours of operation. Also, any external case can be used that matches your hard drives specs...size, IDE, SATA ect...
Hope this helps you,
George
Jun 22, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
688 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
