Question about KitchenAid KGST307 Gas Kitchen Range
Control panel black -No display
I self cleaned my oven for 3 hours and when i came back the display was black...but the burners on top still work fine. I unplugged the power and plugged it back in...still no display. Was wondering if there was a reset or fuse somewhere I was missing. Please adviseModel KERH507Y  or  JBP95 KitchenAid
  • Michel Rondeau Oct 02, 2011
    I have the same problem, what is the solution?
    Sergeant:
  • 199 Answers
No reset fuse inside, by the power cord, also lcd display might be gone hope i helped
Posted on Jul 20, 2009
The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My problem is i did a self clean on the oven and it went through the 3 1/2 hour cleaning and as soon as it was done cleaning the control panel went completly dead. all 4 top burners work but no light in...
The self-cleaning cycle gets extremely hot! The surface of the oven inside becomes a catalyst with the heat. It sounds like a something on the range got hot like a circuit board. It is possible that a fuse or a fusible link may have burned up causing this issue. Did you check the plug for power? Maybe the GFCI tripped when the cycle was running. If you have power to the plug then you will need to start by removing the back panel and check for any fuses located on the circuit board. Check for any loose wires and use a multimeter to check for voltage going to the control panel. If you find any wires that look melted that might be a fusible link and will need to be replaced.
Sep 20, 2009 | KitchenAid Kitchen Ranges
Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
Apr 10, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Frigidaire self cleaning oven MODEL PLCF398DCC
you should be able to simply hold down the contro lock button for 3-5 secs, and it shoudl unlock for you
Nov 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
F1 Error code
i just had this same issues happen after running the self clean cycle. f1 error, fan would come on, fan would turn off. its not the control board, its the temperature probe. I picked up the part for 40 bucks and put it in myself. plugged the stove back in and it was good to go. the old temperature probe's wires melted during self clean. note to self: clean you over the old fashion way with some elbow grease.
Mar 30, 2007 | Kenmore 46123 Stainless Steel Electric...
KitchenAid KGST307 Gas Kitchen Range Logo
652 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
