Question about Kitchen Ranges
I am getting an F13 error message on the control display of my kenmore Elite electric range model no. c970=688022
  • 601 Answers
Hi...
F13 is a communication error. Disconnect power to the range for at least 1min.
Power the stove back up and if the fault reappears your gonna need one of these
http://www.repairclinic.com/referral.asp?R=154&N=1157452
Thanks
Smith
Posted on Jul 20, 2009
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
What does code F-13 indicate?
Why is my Kenmore oven giving me an F13 error code ...
www.shopyourway.com > kborders06 > Questions
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad.
Sep 08, 2015 | Kitchen Ranges
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046613500/0583/0124160/R0507023/00001?blt=06&prst=0&shdMod=79046613500 for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Dec 08, 2012 | Kenmore Elite Sears & Other Brands...
I have a Kenmore Elite Electric Range Model # 790.4671 that is flashing a F11 Error. Any advice on repair? Thanks
Hello, welcome to FixYa.
I understand you have the Kenmore 7904671 range, correct ? I also understand based on your post you're getting the F11 error message, correct ?
This range is built by Electrolux/Frigidaire as you may or may not know and a
ccording to the service manual, here's what it is and what you can do
...I will also add, Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault code.
("TST" is the touch sensitive panel and EOC is for Electronic oven control or timer)
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless either of the control's has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Oct 14, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
My kenmore elite electric slide in range suddenly had the word error appear and the code f13. The oven won't go on, but the range top works
Need the model number (specifically the 1st 3 digits ) too determine who manufactured it for Sears then can tell what the fault code means for that brand. You might try shutting the breaker off 20-30 mins see if it resets itself.
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Kitchen Ranges Logo
216 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
