Coby 705-4G mp3 player will not load to my My Computer. When I plug in to the usb port its saying ''MTP Device Driver installing'' then its saying mt device has been successfully installed but MTP device is looking for a preconfigured driver folder. My media player doesnt detect the device. What am I doin wrong here?
The problem was buying the thing they ****!
Posted on Jan 31, 2010
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
Feb 21, 2011 | Coby MP-30523 MP3 Player
Coby mp3 player mpc7095
Install the software compatible with the mp3 player . Some computer acess the device only when the suitable sofware is installed.
Dec 03, 2009 | Coby MP-705 Digital Media Player
I put the usb port in the computer and it will say the computer has found new hardware and for me to install it when i do it will say hardware can't install. what do i do?
Selecting or switching automatically MTP < > MSC
Connecting the player before a media software program is installed, the player will connect as a flash drive also called removable disk in MSC mode.
There are 2 settings for connection mode in the player, MTP and MSC.
See page 36 of the manual for more information and how to set the USB mode:
http://www.cobyusa.com/files/manuals/MP705_MN.pdf
USB mode MTP
Install Windows Media Player 11 for MTP connection to the computer.
When needing a media player update from Microsoft see:
http://www.microsoft.com/windows/windowsmedia/default.mspx
USB mode MSC
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine:
ending up with "Cannot Install this Hardware".
Solution:
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Note: when using MSC mode always safely remove hardware, the players' removable disk. The icon in the right corner of the task bar.
Oct 01, 2009 | Coby MP-705 Digital Media Player
Windows not Recognizing COBY MP705-8G
Make sure you have plugged your Coby MP3 player into a USB 2.0 port. The Coby does not support the USB 1.0 standard. If you are getting an error that "This device can perform faster..." your port is an older USB type. I have both types on my computer and the Coby would not install until I plugged it into my 2.0 port.
Hope this helps.
Jun 26, 2009 | Coby MP-705 Digital Media Player
Usb malfunction
I can help you with you Coby 610 mp3 player.
What is happening is that your Coby isn't communicating properly with the computer. You don't need a driver, you just need to repair the Coby's system software.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 16, 2009 | Coby MP-610 MP3 Player
Will not connect with the computer
follow this process
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer and enjoy you ipod
and don't forget to give rating
Jun 16, 2008 | Coby MP-C7085 MP3 Player
Blocked Iriver X20
Yes, try running a format from your computer to the IRiver with it plugged into the USB port. I have done this with several friends MP3 players and it works great. In other words plug your MP3 player into your computer as you usually do and from windows or dos in your accessories run a regular format of the MTP portable device or whichever drive dos says it is. Then presto you can again load music or whatever your MP3 player take into it again.
Jan 14, 2008 | iRiver X20 MP3 Player
MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Dec 29, 2007 | Samsung YP-K3 MP3 Player
MTP Device
Upgrade to windows media player 11. The MTP Driver is installed with it.
Mar 21, 2007 | Coby MPC-848 MP3 Player
334 people viewed this question
 Grubhead
Grubhead
