Question about Zenith Televison & Video
I have a zenith modelznd400 it installs disc spins a bit stops ejects disc. serial 3 du8811nca file # e225515.What could be wrong? Art
  • knut748 Jul 20, 2009
    How do you do that?
  • knut748 Jul 21, 2009
    I bouht a disc cleaner and put it in the machine it spun around fast then slowed up and ejected. I then tried a dvd disc it done the same thing I tried a cd disc it done the same thing. Does the machine have to be hooked up to anouther component like a tv to make it work.Help Art
  • 1,272 Answers
Its a mechanical problem from the disc tray section.The disc tray dosnt fit well inside.
Get it serviced by a technician.
Regards
Anand
Posted on Jul 21, 2009
  • Anand Gupta
    Anand Gupta Jul 28, 2009
    Has the issue resolved? If not, then please let me know so that we can work for a solution!
    Regards
    Anand
  • 813 Answers
Is it happening with all disks?
Posted on Jul 20, 2009
  • 334 Answers
The dvd player is not recognizing the disc. Have you tried a lens cleaning disc?
seth
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Get error message "disc error" will not advance after zenith trade mark stops whirling
I'd like to help but need more information.
1. What do you mean by "will not advance"? Do you mean you put in a disc, it starts up (do you hear it spin?), the trademark is whirling, and then it stops and doesn't do anything else? Can you hear it stop spinning? Does the screen say anything else?
2. Does it do this with any other discs, or just one particular one? ("Disk has been changed" may mean this but I just wanted to verify.)
Nov 23, 2014 | Zenith XBV713 DVD VCR Combo
Disc
Pull the power plug, let it stop spinning, and then re plug it in. See if that helps eject it.
Sep 03, 2014 | LG RHT497H Digital TV Recorder with 160GB...
Vauxhall insignia dvd800
Laser is offline. Needs to be serviced or junked.
Mar 10, 2014 | Car Audio & Video
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Media Center disc tray will not open. When the "Ejecting" light displays, there is a whirring sound for a little bit but the tray does not come out. There is not a disc inside. I have disconnected the...
This is a common problem with optical drives. There is a small band/pulley inside that connects the ejection motor to the gear action, This reduces stress on the gears and it helps with smoother motion while running. The issue comes in where the band/pulley becomes worn out and loosens a bit and this causes a reduction in friction against the spindle the band/pulley is on. You may need to get a new band/pulley for your optical drives ejection system in your media center. The whirring sound you happen to hear it the ejection motor spinning but its not catching on the band/pulley.
Mar 12, 2010 | Bose Audio Players & Recorders
Is it possible to install / import old PrintMaster 7.0 Art Discs?
When you put the Program install disk in follow the prompt but instead of selecting the "Typical" instalation select "Custom". This way the install will instruct you to select the two or one or none Art cd.s. I assume your copy of Printmast 17 Platinum has all 4 cd's?.If not then you will only have installed about clip 950 art etc. instead of 19,000 plus when you install the Art disk 1&2.
The only drawback is that the two art disc's add another 1gb to the hard drive usage.
I hope this helps.
Brian Wright
May 13, 2009 | Broderbund PrintMaster Platinum
Wii makes a horrible noise while loading or ejecting the disc
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 12, 2009 | Nintendo Wii Console
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Can't get a disk to play
I've seen failure of the spindle motor to cause problems like this. Problem can also be a leaky diode in the power supply.
Nov 19, 2007 | Panasonic DVD-S35 DVD Player
Televison & Video Logo
41 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
