Question about Directv H21 DTV Receiver
Low volume on Direct TV channels
I have Direct TV, and on most channels I get very low volume. I have my television up full blast, and there are some channels I can barely hear. I know the problem is not my television as my DVDs play loud and clear.
  • Jonathan Smith
    Jonathan Smith May 11, 2010
    two questions, what kind of cable are you suing to connect the box to the tv, and doyou have the receiver set to variable output?
This is a known and ongoing problem with Directv since June. They claim they are trying to "level" all the channels so they are the same volume level. The result so far is that ALL channels are suffering from low volume. Given this has been going on for two months now, Directv may never solve this - General ineptitude - denials - but if you call and tell them you are having low volume, they will give you a three month $5 credit. CALL and COMPLAIN... the only hope we have to get this fixed is to cost them money and time on their customer support lines.!!!!
Posted on Aug 01, 2010
  • nloudy Mar 20, 2011
    They told me the same thing - working on it. We got a $5 DVR credit for 6 months for something they did wrong or can't fix. If my husband didn't want satellite/cable TV, I'd go back to the old antenna on the roof and just pick up local channels.
    Sergeant:
  • 199 Answers
Your receiver, is not receiving the right frequency on some of the channels contact direct tv, they will fix it for you or give you a new one
Posted on Jul 20, 2009
I changed my connection from coaxial to RCA plugs and it appears as thought the problem has been fixed. The picture is also a little clearer. Hope this helps!
Posted on Jul 19, 2010
I have to turn the sound up full blast when watching recorded programmes. It is fine when watching live tv so not sure if it is the tv or the Sky box, can you advise please.
Mate does your sky box have a volume control as well as your television, I have a sky box(fox-tel)with volume control as well as the television volume control.... I have the television volume up full and control the volume through my sky box(fox-tel).... Hope this helps... CHEERS...
Mar 12, 2016 | Televison & Video
How can I fix a Samsung TV on which the volume is on full blast when turning the set on, not matter what it was set on when turned off.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 10, 2015 | Samsung Televison & Video
VERY LOW VOLUME
Replace the speakers.
Jun 09, 2015 | Sansui 32" TV
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Directv H21 DTV Receiver Logo
3,250 people viewed this question
Top Directv Televison & Video Experts
john milligan
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
