MX6426* - WINXP ME w/sp3 - F11 loop
Problem: stuck with F11 loop for access or boot option into recovery partition while trying to restore HD damaged by Uniblue's Registry Booster to make drv/apps cd for new HD.
* refurbished so did not receive option at first start up to create recovery CD's. Gateway provided one, but after using it on New HD, only loads OS, no OEM drivers or apps.
Have hooked up HD via USB, can see that the recovery is there but don't have a clue how to get to it.
  • 2 more comments
  • 1centwiz Jul 20, 2009
    no, it's the Media Edition of XP, I guess it's different? no clue...
    Thanks for effort to put up the links, but I am only able to see the text on the pages, no download locations or full text answers.
    Gateway support has not been terribly helpful since it's a refurbished laptop. I found most of the drivers but it was a long hunt on line to find the updated ones.
    Currently I'm thinking if I could get in through DOS and set the boot.ini. file properly, then it would boot into recovery partition on the disc. THere I have all of my recovery's saved in addition to full registry back-ups br ERUNT that I can re-install for the registry issues. It's the Gateway Recovery part that I was to keep so I can run the apps and drivers cd that never got run when I recievd the laptop.
    Does anybody know if it's possilbe to get that partition to work via USB connection outside of the laptop? I can read files, but the OS files give me a warning that I have no access to them.
    My thinking is if I can get this HD up and running then I can make the recovery CD's for the apps and drivers and then wipe the ****** and use it for stoage.
    My new HD is big enough to handle the recovery partition, but how to get it over to it is my delima. copy and paste?
    Also, found drive cab file - shows up as rar. would this be the file I'd need to reload all the proper drivers and how would I use it?
    THanks....
  • Aaron Fox
    Aaron Fox May 11, 2010
    Ah I see, I thought you were talking about Windows Millenium Edition, not Media Center. Unfortuantly, I am not familiar with some of the programs you are referring to so I will step out of this until I see an opportunity to add something useful.
  • Aaron Fox
    You are dual booting windows xp and ME?
    Sergeant:
  • 338 Answers
Hi, ipresume u have hooked it up to another PC using a external S-ATA-USB- case, so that the PC recognizes your drive as one of his, but u are unable to boot from it,as it is handled like a thumbdrive.
can u access the data on the disk?
if yes, make a safecopy of everything personal,
you may even try to make a back-up using the
win-back-up function, just to have a complete copy of the harddisk...,
then format drive(blank it) and put back into laptop.Now setup a new clean copy of WINXP
and yes, you may have to reinstall all the drivers+progs+private data as well...
I hope this option works for you.
Posted on Aug 04, 2009
Operating guide
is your hard-drive the boot-drive, if not, change boot order by pressing F8 or F12 just after hitting the start button, and choose the hard-drive that has the C:\windows on it.
or hit F11 and access hidden recovery partition with HP pavilion How to Access the Hidden Recovery Partition in HP Pavilion
Mar 23, 2014 | HP Pavilion Computers & Internet
No recovery disc to reload operation system on my latitudeD610 laptop
usually these have a recovery partition. Try F11 at startup to boot into it.
Sep 20, 2012 | Dell Latitude D610 Intel Centrino 1.86ghz...
I have restored BIOS defaults and believe in doing so moved OS to D: and recovery to C: so now can't access Recovery by pressing F11 on boot. I think this is because I've messed about. Any help...
Can you still get into windows on the system? If you can, there is a chance you can force the recovery partition to boot. What you do is go into the control panel and select Administrative Tools / Computer Management. Under Storage select Disk Management. Now highlight the recovery partition and right click it. (Recovery Partitions usually are no more then 10GB in size and may have no Drive letter associated with them, and may be labeled as hidden or "unknown") Select Mark Partition as Active.
If you can not get into windows and would still like to try marking the recovery partition as active then reefer to this link for a couple alternative options (requires downloading a boot CD) http://thpc.info/how/make_active.html#gpart
Now reboot the PC and press F11 or F10, F12 etc.., which ever command is supposed to get you into the recovery mode. In most cases this should now work.
Regards, Chris
Jul 09, 2011 | HP Compaq dx2450 Microtower - KR611UTABA ...
How do I access the recovery partition on my systemax pc.
These are usually accessed in one of three ways:
At startup, you may get a prompt to press F11 for recovery (or something similar).
You may also have a menu item in the programs that lets you run system recovery.
Finally, you may have a system repair CD that when used as a boot device will allow you to access the system recovery options.
Jun 30, 2011 | Computers & Internet
Need recovery disk for pc have none
By default your computer has a recovery partition, which can be accessed by hitting F11 key as soon as you start the computer, Keep tapping the F11 key and you will be able to access the Recovery manager, Select the option to do a system recovery and it will get restored to original factory condition.
Note: you can only access the recovery partition if you have not made any changes to the Original Operating system and the Hard Drive.
For any further assistance please feel free to leave your comments.
Thank you for choosing Fixya
Mar 03, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
I want to know if my laptop has a recovery program on it? N how to find and use it please
By default all the hp notebook and desktops come with a recovery partition. To access it boot the computer, and on the Compaq logo Start Tapping the F11 key on your keyboard. This will take you to the Recovery Manager. Click on the Advance options button to get the various options for recovery and backup.
note: you will be able to access the Recovery partitions only if you have not made any changes to the system hardware or Operating system.
Hope you find this information helpful.
Thank you for choosing Fixya.
Jan 05, 2010 | Compaq Presario 700 470024-192 Notebook
F11 problem
Means you don't have Restore patrician on the Hard Drive.
Did you replace or reformat hard drive after you purchased it?
Mar 27, 2009 | HP Pavilion dv9000z Notebook
Recovery option on boot doesn't work
its prob the partition for recovery has been deleted
or corrupted. u need to use cds now
Mar 27, 2009 | HP Pavilion dv9700t Notebook PC
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
