Question about SanDisk Sansa m230 MP3 Player
Still won't work
I have tried to format this thing and the comp. says unable to format. I've tried pushing the menu button to get the menu to come up(as suggested) .....No luck. This is getting frustrating. It says there's no free space yet shows no playlist and won't play anything either. Please Help!!!
  • angdiane Nov 20, 2007
    I can get the menu to come up and I can go to settings. But when i scroll down to USB it won't let me open the submenu. I'm ready to trash the MP3 player.
  • 626 Answers
Change the MODE and try formatting again.
Best of Luck.
Please RATE my solution at the bottom.
Posted on Nov 19, 2007
  • Timothy D
    Timothy D Nov 20, 2007
    There may be a fix for it, but youll have to call SanDisk to see.
    SanDisk Technical Support 1-866-726-3475
    Best of Luck.
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
The items that are blinking are items that can be
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Hi, I'm having trouble with my marantz recorder. I've reached the 999 track limit, but despite deleting older tracks it still won't let me record. The solution must be something basic I've...
Since you have reached the 999 track limit, it is possible your CF card may have been corrupted.
On page 28 of your manual you should find the instructions for formatting your CF card.
"How to Format a CF Card."
This may get you going again.
Hope this helps.
Sep 14, 2011 | Marantz PMD660 Digital Voice Recorder
It first started when I accidentally pushed the button of Dell Media Direct. I shut my laptop as soon as I knew that It's not the power button I pushed. When I opened my laptop, an error page came out. A...
keep pressing F10 button as you start the comp. you will enter the boot menu. Select the BOOT FROM CD option and this will start the windows installation.
Dec 28, 2010 | Dell XPS M1330 Notebook
Syncronizing not comp[leting between windows media and MP3
(to clear or 'erase' skip to format -below)
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
Most other problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 03, 2009 | SanDisk Sansa Clip MP3 Player
Pictures Lost
if you can use yor camera as a card reader. ie plug it into your comp and the drive shows up then use something like this: if you've used it many times since the format it might not find anything good luck
Aug 28, 2007 | Samsung Digimax S630 Digital Camera
When i tried to format the mp3 it it works on the comp but then when i diconnect the usb it just says format error
Try using the format option on the mp3 itself. Hold the "menu" button, scroll through the options to the "advanced menu". Select it n select format. It worked for me.
May 10, 2007 | Sony NW-E507 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
