1. Turn dial selector to the "off" position and plug timer into three conductor outdoor outlet. 2. Turn dial selector to timing interval desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs, dusk to dawn, etc.). 3. Plug outdoor lights into Easy-Setâ„¢ Timer - lights will turn on automatically at dusk. 4. Lights turn off 2 4 6 or 8 hours later depending on dial selection
Assuming I have the right model for you check out the bottom of page 12. Basically you need to press either Timer 1 or Timer 2 buttons so each does not have the light below it illuminated. The light on shows the timer is active, light off inactive.
Try pressing the first 2 buttons on the left, and the last button on the right of the timer all at the same time.
It may differ to this depending on the actual model, but it is usually a combination of 2 or 3 buttons.
Hope this helps, if it does solve the prob, please feedback.
Thankyou.
Setting the ON time (Example: AM 10:15). 1. Press the TIMER button on the Unit for more than two seconds. The Timer indicator lights up and the hour digit of the current ON time blinks on the display. • When the clock is not set, “CLOCK” and “ADJUST” appear alternately on the display. Set the clock first. Press the ¢ or 4 button on the Unit to set the hour you want the Unit to come on. Pressing the ¢ button moves the time forwards and pressing the 4 button moves it backwards. Hold down the button to move the time rapidly. 2. Press the TIMER button. The minute digits of the ON time blink on the display. Set the minute you want the Unit to come on, using the ¢ or 4 button. 2 Setting the OFF time (Example: PM 1:30). 1. Press the TIMER button. The hour digit of the OFF time blinks on the display. (The same time as the ON time will be automatically set.) Set the hour you want the Unit to be turned off, using the ¢ or 4 button. 2. Press the TIMER button. The minute digits of the OFF time blink on the display Set the minute you want the Unit to be turned off, using the ¢ and 4 buttons. 3 Selecting the music source. 1. Press the TIMER button. The “TUNER” or “CD” blinks on the display. 2. Press the ¢ or 4 button to select the music source you want to listen to. The display changes as shown below. TUNERôCDô(back to the beginning) 4 Setting the volume level. 1. Press the TIMER button. The current volume setting blinks on the display. 2. Press the ¢ or 4 button to select the volume level. -- :The current volume level will be used. 0 to 50 :When the timer is turned on, the Volume will be automatically set to the selected level. 5 Press the TIMER button. The timer setting is completed and the display returns to the display before you set the Timer. The Timer indicator remains lit. 6 Before turning off the System, prepare the music source selected in step 3. TUNER: Tune in to the desired station. CD: Insert a CD. (Playback will start from the first track at Timer on.) 7 Press the % button to turn off the System. In standby mode, you can see the Timer indicator ( ) on the display. • When the timer turns on, the Timer indicator starts blinking and the prepared source in step 6 will be played. To cancel the timer, press the TIMER button. The Timer indicator ( ) goes out on the display. To re-activate the cancelled timer, press the TIMER button to light the Timer indicator ( ). At this time, you can see the current timer settings. Each setting appears on the display for two seconds in the order of ON time, OFF time, music source and volume. To change the timer setting, repeat the setting procedure from the beginning.
1. Set the oven to the required temperature. 2. Press the g button. 3. Set the total cooking time with the + button (see the example in the illustration right, showing 1 hour and 30 minutes). 4. Press the h button. 5. Set the cooking finish time with the + button (the example in the illustration shows 12.30 hrs.). After setting the display shows the time of day and indicates »AUTO«. ❑ The oven cooling fan will start immediatley. ❑ At the pre-set time, the oven will be automatically switched ON. ❑ The settings can be corrected at any time. ❑ When the pre-set cooking finish time is reached, a signal sounds and the oven is automatically switched OFF. To turn the signal off, briefly press the h button. 6. Turn the oven selector switch to the 0 position. 7. The »AUTO« symbol blinks. Important: It must be switched OFF by pressing the E button.
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Hey hpnotiq_babe, Directions on how to set the self timer on this camera are on page 27 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I have copied the instructions on how to set the self timer on your camera below. I hope this helps! ● Selecting the self-timer 1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode. 2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor. A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work. •2SEC self-timer ( ) : Pressing the shutter button will allow an interval of 2 seconds before the image is taken. •10SEC self-timer ( ) : Pressing the shutter button will allow an interval of 10 seconds before the image is taken. •Double self-timer ( ) : A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time. 3. When you press the SHUTTER button, the picture will be taken after the specified time has elapsed. http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=11 Sincerely, Allan Go Ahead. Use Us.
