Question about Dell Latitude D510 Notebook
DELL Latitude D510
When I turn on my computer before Windows can load a blue screen comes up saying UNMOUNTABLE_BOOT_VOLUME. I tried starting it up in safe mode got the same results. I also did a pre-boot system assesment by holding on to FN, everything was ok except for an error that was detected on the harddrive during the DST short status test. I out of ideas, please help.
    Welcome Back:
    Visited the website for 2 consecutive days.
Re: DELL Latitude D510 - Dell Latitude D510 Notebook PC Laptops
How to clear bios password.
Posted on Aug 22, 2008
This worked great on a Dell Inspiron 1000 thanks
Posted on Dec 25, 2007
  • 50 Answers
Unmountable boot volume means that either your system is corrupted, your boot.ini is damaged, or your boot sector is corrupt. Try this:
"You can boot to the XP cd and when you see the Welcome to setup press the letter R
You will get a dos prompt
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows"
Posted on Nov 19, 2007
0 characters
3 Points
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
My DEll D505 has the blue screen of death which says unmountable boot volume and I do not have the reset disc. I do no know what to do. Please Help...
In that case borrow an Windows install disk from a friend and using your own key reinstall with it. After that you will have to install the drivers yourself. You can download them from here
Sep 26, 2010 | Dell Latitude D505 Notebook
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
Latitude D400 Laptop- unmountable boot volume
there a hard disk problem, probably has no hd-disk. you must reclaim for a new working hd.
Jan 02, 2010 | Dell Latitude D400 Notebook
Place a Windows XP disk in to a drive and just after pressing power button keep pressing F10 or F12 to get to the boot menu then choose cd/dvd drive and follow procedures from the screen to repair or install system. ANother way is by pressing F1 or F2 or Del just after pressing power button to get to BIOS the go to Boot options and set firs cd/dvd drive then press F10 and enter.
Jul 20, 2009 | Dell Latitude D600 Notebook
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
Dell latitude d510 laptop
This link should take you to a page to create a boot disk that will let you get into dos. From there you can format c:\ /s and start over.
Dec 23, 2008 | Dell Latitude D510 Notebook
Blue screen and windows shut down
For the issue of BSOD of Unmountable Boot volume, the only solution so far is to reinstall the system. If you are unaware of how to do it, it would be easier to contact Dell technical support and allow them to guide you thru it. (if your warranty is active, it's free)
Dec 21, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D510 Notebook Logo
437 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
