Question about Grundig Satellit 800 AM/FM/SW Radio
I need to purchase a power supply for a grundig 800
Satt 800 turns itself off and wont reset. I NEED IT REPAIRED! Am in Alabama
R.L. Drake in Ohio can and does repair the Grundig 800 Millennium receiver.
Contact John Kriner there, and advise him that I sent you.
See info below.
Joe Rotello
Knoxville, TN
John Kriner - Lead Tech. Knows Grundig 800 inside and out
jkriner@rldrake.com
USA
R.L. Drake
230 Industrial Drive
Franklin, Ohio 45005-4496
Phone Numbers:
Office & sales phone: 937-746-4556
Technical support and repair parts phone: 937-746-6990
Aug 21, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Hi i have a grundig gu22dvd the power supply keeps turning off can i buy a new poers lead and transformer
helen366, if unit continues to do same thing, I suggest you contact Grundig for warranty service to put it right again!!! You must tell them that it should not have premature failure of the internal "switch-mode-power-supply" and they should replace the unit with new or refurbished same model free of charge.
12fixlouie
Sep 24, 2010 | Grundig GU22DVDPX 22 in. LCD TV
I have lost the instruction thatwas provided when the radio was purchased. How can I secure a replacement? Thanks
You can download and print the manual here. http://www.radiolabs.com/downloads/manuals/grundig/S800manual.pdf
May 04, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Jan 30, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
Looking for manual
HI,
DOWNLOAD PDF FILE FOR 800 SATELITT
GO TO GOOGLE ENTER SAT 800 GRUNDIG PDF
YOU WILL GET A MANUAL FREE OF CHARGE....
Nov 13, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 AM/FM/SW Radio Logo
378 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
