Question about Sharp XR-10X Multimedia Projector
Projector Light could not come-up again
I have two major problem and it goes thus; I select an option to lock the keys (the 3rd options) and I have no remote. Since then all the keys have been lock. I can only use the projector to transmit from a DVD video machine only. In an attempt to solving this problem I press the either the power-on button or the power-off button While pluging Sharp XG-P25X projector conference series, since then the projector light can not come up again. Though i am a computer technicians and i have try to solve this proble on my own but I could not. My brother in law bumped our ceiling mounted projector and it fell. He caught it on his back, and it kind of rolled down his side slowly with him grabbing at it, then landed on the floor. (from about his knee) We plugged it back in and it comes on and the light goes to green. Notevision comes on the screen and then it shuts off and the light goes to flashing red. After reading some posts, I took it back down and cleaned the filters out, they were dust-filled. But it still does exactly the same thing. Can anyone help?
    Problem Solver:
  • 9 Answers
Sounds like the lamp was jostled enough to damage it or it just needs to be re-seated. remove the lamp module and put it back in. Since the filters were quite dirty, the lamp was likely on it's way out to start with. Lamps ain't cheap but their life can be greatly extended with routine filter cleaning, something the manufacturers don't stress hard enough.
Good Luck,
Posted on Jan 08, 2008
Is there a master password to Dell projector 1220s projector
You can contact Dell support below:
Mar 13, 2015 | Dell Computers & Internet
Why wont my laptop connect to my tv via hdmi
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
Aug 23, 2014 | Acer Aspire 5350 5750 5750g 5750z Series...
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
I have my computer on and connected to the projector viewsonic pj550. I then turn on the projector but it does not read the computer.
Assuming that you have all the connections between your computer and the projector already performed, you should check in you computer's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops and computers need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops and computers will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
Some computers have an icon in the tray area at the bottom right part of your screen for the display characteristics. Clicking on it shows a menu where you can select the graphical options for your computer, and there must be an option for the selection of a dual display mode through which you can select computer + monitor (projector)
This same function can be called from the Control Panel in your computer. Assuming that you are using Windows XP, you will need to go to Start > Settings > Control Panel > (Graphics Adapter Configuration Setup), where (Graphics Adapter Configuration Setup) will depend on the graphics adapter chipset used in your computer (Intel, nVidia, ATI, VIA, etc). There, you might have the same options to select a dual presentation mode, to show the things in your computer display and/or your projector.
If even with these indications you are still not able to make your computer show its information through the projector, please send us more details on how you connected your computer to the projector, as well as the brand and model of your computer and the operating system you are using.
Hope this information can be helpful!
Mar 09, 2011 | ViewSonic PJ550 Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
I have added a memory chip. Can I transfer pictures from the phone to the chip, when the phone is full. if so, how?
If you have a USB cable, you can connect the phone to the PC and from the PC you should be able to access both the phone memory and the chip as two seperate removable drives. So then simply transfer the pictures from one to the other through the PC.
If you don't have a USB cable:
  1. Open the main menu (joystick center button)
  2. Enter file manager (3rd icon from top on leftmost column)
  3. Select "on phone" tab (by clicking joystick right twice)
  4. Select "Pictures" folder (should be 3rd folder)
  5. Click "more" (right option button) --> "select" (7th option) --> "select all" (2nd option). Now all pictures should have a checked checkbox on them.
  6. Click "more" again (right option button) --> "manage file" (3rd option) --> "transfer" (2nd option) --> "memory stick" (1st option).
Apr 28, 2009 | Sony Ericsson K800i Cellular Phone
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
5. Press 41. Panel announces, Option 41, press again for next option or done to
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
Accidently hit the key lock button
You can overcome this problem by disconnecting the AC power cord, to turn off the power. Then press and HOLD the select button and reconnect the AC power cord.
This should clear the Lock.
Hope it helps
Dec 08, 2007 | Sanyo PLC XU50 Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
125 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
