Question about Proscan 19LA25Q 19 in. LCD Television
Will not turn on no power proscan tv model no 26la30q
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 20, 2009
Won't turn on
Proscan tv's use cheap capacitors in the ps area. Fix is replace with exact values.
Feb 02, 2014 | Proscan 26LA30Q 26 in. LCD Television
26" Proscan wont turn on.
Check its back light inverter board, and associated voltages, comes from the main power supply board.
google.com/+GopakumarGopalan
Nov 16, 2013 | Proscan 26LA30Q 26 in. LCD Television
Proscan 26LA30Q Image in Psychedelic Colors
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | Proscan 26LA30Q 26 in. LCD Television
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
26la30q wont turn on
Hi
You have to start checkin from its main ON/OFF switch itself. If the switch have any contact contact trouble, the set will not turn On, even though you hear the click sound from the switch. If switch is Ok, then you have to come to the power supply regulator board. It can be easly recogonized the powe supply regulator boad. The main supply line will go straight to it. There will be more that 5 or mor secondary voltages from it, according to Tv model. These secondary wupplies will energzed only after the power supply switching circuit work properly.
Ther is a fuse [ a cartridge type; replaceable]. Check the fuse first. If it has blown; be carefull when you replace it; because there must be some reason for the blowing of that fuse. It is really a protection device. Before replacing it, you have to check the entire power supply board for some short circuit. If you have sound knoledge in repairing Switched Mode Power Supply [SMPS]; just proceed. Otherwise get it repaired by any experienced service technican or by authorised service center for Proscan. OK.
Jul 08, 2011 | Proscan 26LA30Q 26 in. LCD Television
Lost channels on proscan tv
Press the menu button on your remote.  That should give you the main menu where you can go into add/delete channels and do an autoscan to only save channels that are good.
Mar 04, 2009 | Proscan 26LA30Q 26 in. LCD Television
What is the resolution for the proscan model 26LA30Q 26". Is it a 720 or 1080 resolution .
it believe it is 720. I know it does not say anywhere. I found one website which sold this TV and it stated it was 720 resolution
Dec 15, 2008 | Proscan 26LA30Q 26 in. LCD Television
Universal remote
you going to have to get the same remote that came with the tv .no other remote will work.
May 24, 2008 | Proscan 26LA30Q 26 in. LCD Television
Manual
http://www.oncorpus.com/
This is the link for the company website where you can download the manual for any Proscan TV. I found this info through Wikipedia.
Jan 27, 2008 | Proscan 26LA30Q 26 in. LCD Television
Remote Code
The code 11178 worked for us for our Comcast remote.
Lauren
Jan 13, 2008 | Proscan 26LA30Q 26 in. LCD Television
Proscan 19LA25Q 19 in. LCD Television Logo
956 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
