Question about LG KG800 Cellular Phone
BIGG PROB WHEN i put my at&t sim card in my lg touch fone...it says no service when i dial a number??? whyyyyy ???
Help i have just transferred a sim from one S5 to another and want to transfer the number as well.vodafone tell me mobile settings,then profile then change number.were do i find this
if the phone does not ring when the number is dialed
The mobile number has to be done by Voda phone. The IMEI has to be put into the Voda Phone network against the Phone number.
Dial #06# into the phones dial and the IMEI will show .
Note the IMEI
if you want the phone to have the mobile number in the sim for labeling it.
Apps - Contacts
touch finger on the plus
touch finger on Sim Card
go down to phone number
put in phone number
press on done from key pad
press on save top right of screen
Jan 09, 2017 | Cell Phones
I forgot my security code for LG CE 0168,my IMEI A 353529-06-984666-6 IMEI B 353529-06-984667-4 is it possible that i reset or change the code because my fone is locked.
If you mean your SIM Pin, contact your service provider. If you mean your Phone PIN, contact your LG support. They should be able to reset it. And, do not make your IMEI number public.
Jan 08, 2015 | LG CE0168 Cellular Phone
Ay lose paswords in may fones samsung sgh-x160
1-Put the non T-Mobile SIM card in the phone.
2- Turn on the phone, "wrong sim" should appear on the screen.
3-Dial *2767*3855# and wait.The phone will reboot,and the non T-Mobile SIM card in the phone will work,but this is only a temporary unlock step
4-Dial *7465625*638*00000000*00000000#.The phone will say it is personalized.
5-Dial #7465625*638*00000000# .The phone is now unlocked permanently.
6-Dial *#7465625# to check the lock status.
~KenjiFox
Jan 07, 2011 | Samsung SGH-X160 Cellular Phone
When i am attaching hands free the outgoing call is activating automatically what can i do
I have done this on my ittle LG flip; I realized I was inadvertantly pressing the auto-dial while I was inserting the phone into cage & closing gap; had no idea why phone was ringing!!! Check all the buttons on both sides of phone; check what happens when you press each button....OR, go back to your User Manual & be sure you arent in an auto dial mode.
Alternately, you may be hitting a one touch dial; check for this by going into the Menu, then Settings, then something that looks like Dialing Match or Set Speed Dial; if it indicates something similar to ^auto dial last number^ then you can resove this by changing that setting. The best way to play with this & not be calling anyone is to remove your SIM card first (remove battery & slide the little card out); most phones will still power up, they just cannot connect any calls & the SIM has your directory info only, not the phone menu.
All the best, I hope some of this helps, and have a safe, happy holiday season.
Nov 17, 2010 | Cell Phones
It says puk
when your phone say puk then call to your sim costumer care and ask about puk. its related to sim, not to your phone
Tenzin
May 12, 2010 | LG Neon GT365 Cell Phone
PUK Blocked? What does that mean?
The PUK & PIN codes are Security Codes that are on the SIM card. PIN( Personal Identification Number ) PUK ( Pin Unlock Key). when the PIN code in entred wrong the SIM automatically Blocks the PIN. to unlock the PIN you need to Enter the PUK. but if you enter the PUK wrong the Entire SIM is Locked.
The PIN Code & the PUK codes are Only Known by your Network Provider. you have to get in touch with them to get the codes. how ever if you have PUK blocked you will have to get a replacement SIM
May 09, 2010 | LG Xenon GR500 Cell Phone
Cell phone got wet. It doesn't work anymore. How can I retrieve phone numbers, etc?
hello,
u hav to put ur battery out and open ur mobile fone after it put ur mobile fone board in sunlight for 2 or 3 hours then close ur set and put ur battery into it and turn it on..
Jan 06, 2010 | Verizon Communications LG enV Cell Phone -...
How do i put the memory card in the lg phone
open the back of the fone, take out the battery, with the sim card facing you on the upper left of the fone, the memory card is spring loaded, in a slot to the right of the sim
Jul 26, 2009 | Cell Phones
Locked Sin Card
you will have to "block" your card by putting in the wrong password 3 times,you will then be asked for a puk code,when putting in your puk code,you will be asked to put in a new pin number. ask your service provider for your puk code.
Jul 20, 2009 | Cell Phones
Subsidy lock
i had the same prob jsut put a boost sim in it and wait for about 48 hours with the fone on and wit hfull service the whole time they will trace the fone and check to see if it is reported stolen and if it isnt they will unlock it is an automatic program built into the older fones kinda like lojak this should work on about 75% of the older fones out there ok and ps if it is "hot" jsut change the name the fone is registerd to in the fones menu in boost fones it is under my info ok that is all you will need to do
Jan 31, 2009 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
