If it's still under warranty the TV Service Shop will fix it for free if they are a qualified Polaroid servicer. If not I believe you are having problems with the power supply board not sending the Audio board the right voltage. Could be the Audio board itself. A Good TV Service Shop should be able to fix it. May cost you between $100 to 200 for the repair. Blessings, A/V Media Tech Guy
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Polaroid FLM-2632 Television
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as...
(More)
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as well as a HDMI cable.
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then...
(More)
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then nothing and i havent had any picture since. its not my cable box because all other tvs work. i brought mine down stairs to try a dif. connection but still nothing. ive done the factory reset and uto search countless times but im at a dead end
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and...
(More)
TV is about 18 mos old and during last mos have noted a black line forming from top to bottom and the right side of TV almost like when you used to have to Degas you PC monitors Stays in same stop. it there as soon as unit is turned on Thanks for help
