Question about Zanussi ZCG7550 Gas Kitchen Range
Installing my Zanussi cooker
My brother in law (corgi registered) attached my hose on my new cooker. After he left I plugged it in and within 10 minutes the electrics had blown in my whole house. after resetting the RCD switch, it happened again. What could be possibly wrong
2 Suggested Answers
SOURCE: zanussi cooker
thanks but solved the problem.The white wire was loose in the socket on wall.
Posted on Oct 15, 2008
  • 333 Answers
SOURCE: Zanussi Oven Fan ''Ringing''
Your fan blade is probably touching the metal shroud around it or the blade is loose. You can check this by gaining access to the fan and visually looking at it. Please do not do this with the unit plugged in, electricity kills. I hope this helps.
Posted on Nov 23, 2008
0 characters
1 Points
We have just moved house and have been left a Belling Platinum Dual Fuel db2 Cooker and cant get the ignition to work. Can anyone suggest what we should do?
by cooker,do you mean a stove? is it gas?is the gas knob in the "on" position?is the stove plugged in?
i clean out apartments to get them ready for new tenants. if the ignition clicks on,but the burner isn't lighting,it might be dirty. i soak the burners in hot water overnight. scrub with a wirebrush.poke a needle in all the openings & on the ones in the stove. dry thoroughly & see if it works.
if the ignition isn't clicking at all,one of the components in the electrical box might be broken.i wouldn't mess with gas or your gas & electric supplier or a repairman to find out what's wrong & see if it's worth fixing or not.
Mar 30, 2015 | Belling Kitchen Ranges
I live in London U.K. and have a ERSD48'' Duel Fuel Range which was already in the flat I have just bought. Unfortunately one oven does not work and the other only heats to one heat. Please can you tell me...
Cooker Services est 1977. Dealing with the repair and installation of all gas and electric cookers and built in oven and hobs.Corgi registered. Free call out - works on a 'no fix no fee' basis, free estimates.
phone: 01255 814645
Mar 27, 2008 | Kitchen Ranges
Not sure what flooring needed to site Rangemaster
Hi, You can place your range cooker on any floor, but make sure it is level..
Feb 27, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster Disconnect the gas to move house
I dont know if your in the UK but if you do disconnect your gas feed the way MrMark has mentioned you will be breaking the law.. you'll need to be corgi registered to do it that way.
Again if you are in the UK, some gas supplies were fitted with a quick release system.
With this all you need to do is slide your cooker out, locate the connection at the wall, not the back of the stove.
Press down on the top of the connector and turn the pipe coming out about 1/4 of a turn and it will release and self seal the gas outlet.
Jan 28, 2009 | Rangemaster 110 (Gas) Kitchen Range
Zanussi cooker
Oct 14, 2008 | Zanussi Kitchen Ranges
I have recently had a corgi registered plumber remove a gas fire with back boiler from my living room and he blanked off the supply as we no longer require a fire in its place. we also have installed a new...
Sep 09, 2008 | Kitchen Ranges
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit
or ring freephone 0800 408 5500
Jun 09, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Hi lisa not to sell cookers only to fix them , try asking for you money back or go to the small claims court for you money or send them a bill for the work needed to fix the gascooker , if they are a dealer in gas cookers them might not want to go down this road or there is the trade description act ,
lisa thats the best i can offer it will be a fight but the small claims court is there to help i used it twice when things where sold and where bad i won both times hope this helps ,paul
May 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven heat
The problem with you oven is the FFD (flame faliure device ) also known as FSD (flame safety device) The way is works is that when an oven is ignited first time the heat from the low level flame heats phail at the end of the calliary tube which in turn increases the pressure within this tube forcing open the FSD valve to open allowing full gas through. when this fails it restricts the amount of gas flowing through it leaving the oven with a small flame. these are easily repalaced but the law says it must be done by a corgi registered engineer for gas safetey reasons...But 110 % that is your fault. HTH
Dec 04, 2007 | Frigidaire FGF316 Gas Kitchen Range
Zanussi ZCG7550 Gas Kitchen Range Logo
87 people viewed this question
Top Zanussi Kitchen Ranges Experts
ray gallant
 Kaye Day
Kaye Day
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
