Home | Canon | Elura 100 Mini DV Digital Camcorder | Remove tape error mes...
Canon Elura 100 Mini DV Digital Camcorder
Problem for Canon Elura 100 Mini DV Digital Camcorder
Remove tape error message
By jaxdeke on Nov 19, 2007
Every time I try to put a tape in my camcorder it beeps and tells me to remove the tape. This thing doesn't even have ten hours on it. I am very frustrated and would love any suggestions you could make. It seems like this is a common problem that, hopefully has a common solution.
Thanks
Same Problem
May 05, 2009
-   every single time that I put a new or old cassette in now it speed reads it and beeps and the display monitor reads "remove the cassette" i only used it 5 times...less than 16 hours of video what is going on here.....-   vipboitoi
Mar 01, 2009
-   I've had this same problem on 3 different Canon video cameras!-   Guest
Jan 16, 2009
-   Same problem -   Guest
Jan 15, 2009
-   Did anyone find a solution? -   Guest
Nov 08, 2008
-   same problem.  It's not the tape because I've tried old ones that I know used to work and a brand new tape.  Keep getting the beeeeep.  "Remove cassette" message in RED on the blue screen. It isn't moisture.  What else can I try???-   Guest
Solution #1
posted on Aug 17, 2008
Somewhat Helpful)
rockwtf
Rank: Apprentice
Rating: 80%, 12 votes
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon Elura 100 Mini DV
Questions and Unsolved Problems for Canon Elura 100 Mini DV
Do you recommend Canon Elura 100 Mini DV Digital Camcorder?
Answer
Answer
sometimes when I put a tape in, it just starts racing and it says "remove cassette".... (More)
Answer
I lost the software that come with my Canon ELURA 100 A
Answer
My Elura 100 only boots to ''CANON'' blue screen in camera mode. It seems to boot ok in play mode.... (More)
12 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 26, 2008
Canon elura 100.
beep sound,remove cassette message.After removing,not accepting
it again.frustrating.
Kept open for 1 day to dry the moisture.No change.
pls guide.
Canon Elura 100 - first got beep sound 'remove the cassette' message and once removed and tried to put the cassette - its frustrating - not accepting
the tape and rejects immediately after a long gear sound....
Tried with other tapes - no hope.
Pls guide me if anyone solved the problem.
note:just left open camcorder for some time(1 day) to dry the moisture if any - no positive result.
Comment by jay morgan, posted on May 07, 2008
wife and son were in jamaica on mission trip while there started doing
same thing put a tape in record then cant get tape to eject. left it alone
got back from trip i opened side tape slot opened removed tape reinserted the same tape watched a little then opened removed tape. 2 days later
went to put new tape in and a used tape neither would load got message
red x with remove tape. wandering whats up
golfer10
Comment by sharmak, posted on May 06, 2008
After inserting a tape and closing the door the camera appears to try to access the tape and then fails with the remove tape message in RED - looks like the mechanism may be trying to pretension and jamming for some reason - Have tried with many tapes (old and new).
Would really like to find a fix since this was one of my best performing cameras I've owned.
Comment by Guest, posted on Jan 27, 2008
same like those people always got message to remove the cassette
Comment by jc7654, posted on Dec 23, 2007
same thing...first it wouldn't let me eject the tape and now it won't recognize any tape argghhh
Comment by Guest, posted on Dec 19, 2007
The camcorder will not accept the tape... even a brand new one. It says "Remove Tape". Help! The product is one year old and barely used.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon Elura 100 Mini DV...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
