Question about Sanyo CLT-A902 Cordless Phone
SANYO CLT-A230M CORDLESSPHONE requires to enter PIN code
Incoming calls can be received. The handset requires to input PIN Code when I pick up the handset to make a call ? what is the cause of the problem ? how to get the PIN code ? How to turn off this PIN code ? Please help me ! thank you !
Do you need to enter a pin to make calls
Posted on Jul 02, 2010
  • stevennoble2 Jul 02, 2010
    do u need to enter a pin to dial out?
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Sanyo CLT 947
Two solutions. Replacement rubber key pad membrane or re-apply conductive coating.
1) Call Sanyo and see if they have a replacement rubber membrane keypad for your model of telephone. (I replaced the keypad membrane on my Sanyo CLT-2430 cordless phone). In Canada, the Sanyo telephone number is: (905) 760-9944. Their web page is: sanyocanada.com.
2) A rubber keypad repair kit is available from MG Chemicals. Rubber Keypad Repair Kit 8339.
This kit is described on their web page: http://www.mgchemicals.com/products/8339.html
In Canada, this keypad repair kit is available from ElectroSonic. See a description of this kit at: http://www.e-sonic.com/acc/products.aspx?command=detail&partID=8339&partIDExt=281
In Canada, this keypad repair kit costs about $14.00.
Apr 22, 2008 | Sanyo CLT-A902 Cordless Phone
Unlock my phone
These are different types of codes.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset.
Phone Security Code:
This locks the handset, as opposed to the sim card. Some phones will accept incoming calls with this lock
enabled, but many require the code to be entered even to answer a call. You can also set some handsets to
only accept a "new" sim if the phone security code is entered.
Which is the one that you want?
Mar 17, 2008 | Cell Phones
Nokia 6126
There is no magic code to unlock! a phone.
If you want to use the phone on a network, and it wont let you use another network SIM card. then:
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the network that the phone is locked on, and the country you’re in. Then I will give you the codes, if I can, some phones need a special clip/cable to unblock.
SIM pin code:
This is a pin code that locks the SIM card until you enter the correct code. This protects your account, even
if your SIM is put into another handset.
For this code I need the IMEI number to give you the Master Code.
Mar 02, 2008 | Cell Phones
Help nokia n73
Well, the good news are the Master Code is correct for your phone. The bad news are:
SIM PIN Code This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. The default code is set by the Service Provider (often 0000 on Vodafone, 7890 on Virgin). You can change it if you like, but make sure you don't forget the new code.
Phone Security Code This locks the handset, as opposed to the sim card. Some phones will accept incoming calls with this lock enabled, but many require the code to be entered even to answer a call. You can also set some handsets to only accept a "new" sim if the phone security code is entered. The default code varies according the handset make and model. You can change it if you like, but make sure you don't forget the new code.
Special Code/Service Provider Lock Code This code is required to allow a phone locked to a particular network's sim cards to be used with a sim card from another network.
The unlock code varies from individual handset to handset.
Which one is it?
The Master Code is used when you have entered your Security code wrongly too many time. The phone requests it, you leave your phone alone for about 10 minutes, then enter the Master Code.
If you want to unlock the network lock, I need to know the Country you're in and the network you're on.
Then I'll send you the codes.
Feb 25, 2008 | Nokia N73 Cellular Phone
Code problem
please use ufs 12 software for reset ur password
Feb 25, 2008 | Nokia N70 Cellular Phone
Mobile hasbben lock
hi, i need the code to unlock my nokia n95 8gb ,so i can use it on other networks, many thanks
Feb 25, 2008 | Nokia N95 Cellular Phone
Memory locked but dont know the code.tried new card but still says not enough memory
SIM pin code:
Not enough memory means your phone is too full of data IE. Pics, Themes, Contacts, Applications, Games etc...
The phone needs a certain amount of memory to function.
Feb 16, 2008 | Cell Phones
Nokia 6265i
There's a Security Code and Lock Code.
Resetting the Lock Code:
Remove the battery and replace it after 1 hour or more. The default Lock Code should reset to "1234". If that doesn't work try the last four of your phone number.
Resetting the Security Code:
The default Security Code is 12345. If this doesn't work go to your normal interface and type in "#3001*12345*. Go to the Security option, write down the number, then press "Ok". Back out of it all and it should take you back to your normal phone interface. The number your found should be your security code.
Sanyo CLT-A902 Cordless Phone Logo
538 people viewed this question
Top Sanyo Lands Phones Experts
David Burbee
David Burbee
Are you a Sanyo Lands Phone Expert? Answer questions, earn points and help others
