SOURCE: Wont play CD's
saurus
please let us know if you get through to denon. I have been on hold as well for some time. Good to know that the problem is not unique but i hope there is an easy solution.
SOURCE: DVD stuck in my Panasonic DMR-E30
To eject a disk if the unit won't operate (U99, etc.): With the unit
OFF, press and hold "Power", "Stop" and "Channel Up" for 5 seconds.
that's is your problem will be solved.
Goodluck,
Please don't forget to rate me as fixya..
SOURCE: cant get rid of closed captions on dvd player
go to menu turn off captions thank you for using fixya
SOURCE: ROOT appears when i try to play movie!!!
you have to open the root directory then clcick play.
SOURCE: Just got this Toshiba DVR620KU and need to record
Good one!
Sounds like you are doing everything right. Only things I can think of are:
- Make sure the disc is a blank one.
- Try a different disc.
- Make sure the tape you are trying to dub is not encoded with Macrovision copyguarding. If it is a home-made recording then you are OK, but a factory recording on a store bought tape may cause some difficulties.
If you are still having troubles try a complete 15 minute reset by unplugging from the power source.
