Question about RCA Televison & Video
Picture has a a klidescope like picture to it.. is this the picture tube and can it be fixed
  • 458 Answers
It could very well be a De-gauss fault, this is caused by magenetic build up. The solution is to try & gat access to a de-gauss coil, you do not have to remove the back of the TV to fix this. If this has no effect then the positor inside the TV at the power supply stage could be at fault or there is the possibility the shadowmask part of the tube is at fault which would result in a replacement tube.
Posted on Jul 20, 2009
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
Jan 20, 2012 | Apex Digital Televison & Video
My screen starts blinking blue then goes all blue and pops and shuts off. I can wait hours and reset and it will come back on but the problem repeats itself.
This is symptom of bad/ defective blue picture tube that will be replaced to fix this problem.
Blue picture tube replacement is job of professional because it requires lots of convergence adjustments for correct picture and picture tube price would also be bit high.
Let me know to provide you blue picture tube part number info.
Thanks.
Dec 12, 2010 | Sony KP-57WV600 57" Rear Projection...
The picture will be okay one minute and then it will go green off and on
It seems green picture tube in this Sony KP51WS510 rear projection became defective and causing this problem. Replacement of green picture tube will fix this issue but it would be costly fix and professional will do it as it requires lots of adjustments after tube replacement.
Please check with local vt repair shop and ask an estimate of repair.
Thanks.
Nov 15, 2010 | Sony KP-51WS510 51" Rear Projection...
Tv turns on but no pic power button flashing
This is due to compliant of picture tube.Flash is coming due to picture tube compliant.Replacing the picture tube this can be fixed.
Nov 10, 2010 | JVC Televison & Video
How to replace picture tube
Hello
Replacing 27" picture tube must be done very carefully as it will have bulky and care must be taken not to break it. You have to disassemble the internal circuit boards from the TV for that. Make sure to mark every pull out sockets whcih are connected to the circuit board as a rough drawing on a paper, otherwise you may be confused later. You just open the back cover of the Tv, some Samsung models may have locks also with them with fixing screws. Keep the set opened, do a close whatch tho its connections, and board positions. Most of them are pushed in to slots and can be pulled out easely.
Colour picture tubes are integrated with its deflection yoke, as company fittings. We can't replace them alone with an accuracy as they did, which needs sophisticated equipments. normally wires going to the deflection yoke are connected to the board with a socket. A four wire connection is common. Out of them, two is for Horizontal Deflection, and the others two are for vertical deflection. The deflection yoke fitted at the neck of the picture tube has internal windings for both.
Pull out and detach the deflection yoke connection from the board first. be carefull becuse, it may be a little tight to detach, and keep your hands so away from the neck or the present picture tube. If it breaks accidently, may be dangerous. Next look into more connections to be detached. There will ba a two wire connection that comes from the coil fitted around the picture tube, which is called degaussing coil. Pull out the neck board gently and causiously. Pull out all boards out and you have done the half job.
Unscrew the four mounting screws that fixes the picture tybe to front cabin. Gently pull it out from it, you must havav an another to assist you, since it is heavy. Place it somewhere on a blanket upside down.
Seperate the degaussing coil of this picture tube, make notice its connection position, and fit it to the new picture tube, where it will have this coil. It only have deflection coil, and purity magenets on its neck, permanantly fixed. Place this picture tube to the fromt cabin, after placing a smooth folded blanket or so to prevent it from any scratch, screw it to a gentle tight positon inorder to keep it there fixed. Never overtight that screws, as it mat brake the glass envelope of the tube.
Desolder the wire from the old picture tube, note the positions of them. It is best to cut it out from there very close to the soldering point, so that a little bit of wire with insulation be there. It will help you when reconecting wires to the new picture tube, as they are colour coded. Replace all the boards and wires disconnected later according the markings we have done. That is all. Ok
Nov 01, 2010 | Samsung TSL2793HF 27" TV
Screen is green
if it a standard tv thats is come from the picture tube
its look to be the green cathode in the picture tube
it can be fix whit a picture tube regenerator...
hope that will help
May 03, 2010 | Mitsubishi WD-62531 Projection Television
How do i fix a 1988 tecmo ninja gaiden arcade game monitor was playing fin now no picture need to replace picture tube i belive what is the problem with it how do i fix it
It could be a flyback and not the tube itself but if it is the tube you can get another tube for this unit basically any tube the same size will work but then you would need the flyback as well.
I did not understand the total problem as your message was fragmented.
Thanks
Jul 18, 2009 | Televison & Video
12 yr. old 25" G.E. picture fading
I gotta love it when people make up answers. There is no such thing as a "contrass module". I'm assuming the poster meant "contrast". The trouble is your 12-year-old picture tube. It's gotten weak and isn't getting as bright or sharp as it used to. Picture tube manufacturers estimate the useful life of a tube at about 7 years today. There are adjustments inside that might help some, but you need a new picture tube. It's going to cost a lot more than $60 to $75 for that. You're better off replacing the TV.
Apr 22, 2009 | GE 25GT240 25" TV
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
55 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
