Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Sony bravia flashes 13 times then turns off
My 1.5 year old tv model 40v3000 flashes the stand by light 13 times then shuts off. there is a flicker that the screen works and the computer inputs information on the screen. code 13 indicates a balancer? In diagnostic mode it counts 39 errors. No I don't want to take it to a repair man, I am a computer tech & a mechanic. I just can't pay a guy to screw in a new board. I need to know what part has failed.
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
The best thing that would help you is a Service Manual. It will give you red light blinking codes, circuit diagrams, schematics, test points, and part# lists. It will help you diagnose the source of the problem and fix it by soldering in the new part. And most cases the new part cost less than $15 by searching on the internet with the part number.
The Service Manual usually cost under $20 over the internet. Nodevice.com, Eserviceinfo.com, and Servicemanuals.net. If anybody had it, they would. If they don't have one for your TV, you can send a request for the Service Manual under your model number.
It's the best thing you can use to repair the TV. I hope I shed some light on the subject for you.
Posted on Jul 20, 2009
How to fix problem with Sony TV.When turn on sony Bravia TV KDL-40V3000. It comes on and then turns off,
I just fixed one with the same problem. The light flashed 13 times.
I had to cut one trace on the hv board to one of the lamp drivers.
There is a slight but barely noticeable darken line across the screen but the tv stays on now and the picture is good. I don't
know if the lamps can be replaced but why bother now.
Jun 29, 2010 | Sony BRAVIA KDL-40V3000 Television
Whenever I turn my sony KDL40V3000 on it
Power supply problems. check SMPs and other feed back voltage signals.
Apr 05, 2010 | Sony BRAVIA KDL-40V3000 Television
Sony fb3 boad kdl40v3000 Our tv would not turn on except the flashing standby light. Technician told us we need to replace the fb3 board. The cost is $395 for the board and $185 labor. Is this reasonable?...
This is not a unusual amount for repair. Most repair facilities do not like using used parts on sets they have to warranty after a repair. They would then be liable if were to fail and then they would be replacing it at a greater cost to them. You could check with Sony and see what their retail cost is on the part. Their Customer Service Line is 1800-222-SONY.
I hope this helps,
skyassoc
Jul 24, 2009 | Sony BRAVIA KDL-40V3000 Television
My sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
Jun 29, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Apr 27, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-46Z4100 Standby light flashing 13 times
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
Jan 15, 2009 | Sony BRAVIA KDL-40V3000 Television
Tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Dec 28, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia
This unit has a bad invertter board
Mar 05, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
1,435 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
