Air conditioning unit not running but fan keeps running even though thermostat is turned to off, auto, and temp set to highest position 90degrees. 3 amp fuse keeps blowing on the circuit board in the blower compartment. I replaced it 3 times then installed a new thermostat. no change. I can usually figure it out if I got a little input or direction. Any help would be deeply appreciated. I would much rather have a trained expert easily repair my hvac unit but I can only call the professionals in as my financial situation is dictating that I must first try myself.
    Champion:
  • 233 Answers
If the fuse is blowing then this is generally indicative of a short in the low voltage wiring, isolate the wires on the thermostat and the unit ends, use an ohmmeter to verify that there is no path for continuity with no wires touching, if there is then you must pull new t-stat wire to the thermostat, (a guess would be that the green and red are shorted, by the symtoms you gave.
Posted on Jul 20, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
When the air condition reaches the set temperature to cut off the blower motor keeps running and i have the thermostat set to auto on the settings.
check the operators manual but you will probably find that the fan will keep running so that the air in the room is circulated past the thermostat so that the temperature can be monitored and the compressor switched on when the temp reaches the upper limit
May 30, 2016 | Heating & Cooling
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
My lancer 2004 when I start the the engne the fan is running right away even the radiator is still cold and when the engine is turned of the fan is still running for aobut 3 to 5 seconds before it finally...
engine thermostat is a triggering devise to make the fan's work. seconds before it stop when the engine is off, normal for the engine high temperature but it's sign abnormality in the system. fans also runs when the air conditioning unit is "on" to keep the engine operating temperature for its additional load from the unit. need to check if the air conditioning is in "on" position, especially the engine thermostat it may be stuck.
Mar 01, 2011 | 2004 Mitsubishi Lancer
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
The fan has auto ond on selections, the heat looks to be running fine but the fan will NOT shut off.
The thermostat needs to be set for AUTO. If you have it on auto and the fan still goes even though the heater is off then you probably have a stuck fan limit. The limit has a long probe which goes n the plenum. As the heat builds in the plenum at the start-up of a warming operation the bi-metal inside that probe slowly twists around till the temp inside is 110 degrees, the fan comes on and we have warm air in the vents. Then when we have a cozy house the heat shuts down. The fan keeps a going till the heater cools down and the bi-meta twists back around and shuts down the fan. So what goes wrong? The bi-metal simply gets hung up in that position. Tapping on the dial will sometimes release it but it will keep occurring and become aggravating. themobilian_306.jpg
These limits come in various sizes and brands but this is the most common one. If your machine is a newer model then that control board has a fried or stuck relay on it.
Nov 28, 2010 | Heating & Cooling
With my thermostat on auto and on heat, and the furnace turns on, the fan will not turn on with it. If I switch the fan to on it will run after I repeat back and forth from auto to fan on several times...
Well, here is the deal: unless you rewired from two wire to multiple (usually 4 to 10 wires) wires, the fan cannot be controlled from the thermostat, even though the thermostat indicates that it can > it is a physical wiring and fan administration issue.
Unless you have a newer furnace, the fan is controlled by plenum temp. Works like this: burner turns on, no fan until the plenum temp reaches set temp,....then burner off, and fan keeps running until pelnum temp drops, and often the fan may kick on a few more times as this temp depletes.
Oct 03, 2010 | Honeywell Electronic Programmable...
Honeywell Thermostat RTH 7500
In some cases the fan will keep running to remove all the heat from the heat exchanger.It can be set to run shorter or longer.You might check that out.
Mar 16, 2009 | Heating & Cooling
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
482 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
