Question about Plumbing
No pressure showing as jet pump runs
My water was running into the tub last night and all of a sudden the water stopped running. I went down to the basement and the jet pump was running with no pressure showing on the gauge. I hooked a hose up from my neigbors to out side faset and the gauge shows 40 lb of pressure but when I hit the shut off valve it slowly goes to 0. What could be wrong...possible hole in line going to foot valve??
    President:
  • 1,273 Answers
Correct. Either the foot valve, jet valve or leathers. If you pull the well, replace them all, and double the leathers.
Regards, --W/D--
Posted on Jul 20, 2009
Oil type substance is streaking down the side of the tub and apperars to be coming out of the jets any ideas how to fix it
This sounds like bacteria coming from the water lines. When was the last time you ran a cleaner through the jets?
You should run a good Jet Clean type product of Maintenance Product in order to prevent the build up of bacteria in the water lines when the bath tub is not in use.
RodUS Parts Center888-521-6183
Feb 22, 2013 | Home
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
Hot tub is leaking
How severe is the leak?
Is the water level dropping when the tub is not in use? If so you will need inspect the back (inside the tub) portion of each jet. There is a gasket and nut on the backside of each jet body, these may come loose for crack.
If your leak is only when you have the pump running, your leak could be on the suction or discharge side of the pump. Only leaking when there is water pressure.
A temporary fix is Fix-A-Leak - a water treatment that will temporarily repair any crack up to 1/8". Its no guarantee but might help.
Sep 27, 2012 | Pool & Spa
QCA Spa Contol Panel Issues
Flow issues can be frustrating, check each of the following
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter. (Try run system w/o Filter)
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
If none of those help try this. There is a link to s Balboa site for service tech diagnostic help. There are step by step instructions for diagnostics.
Jan 23, 2012 | Pool & Spa
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
I got in the tub one night after the filter had been cleaned out by the roomate who kept the tub running. That night the temp read 94 but was set to 99. Then the OH light came on with Balboa topside...
at pump housing is an upper/lower bleeder ( about 1/2 inch bolt ) unscrew the bolt letting air out until water runs out than tighten turn on unit and loosen bleeder again bleed out any leftover air tighten
Oct 25, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Plumbing Logo
170 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
